97 a4 left me stranded today... lots of vag codes....
Old Dec 1, 2009 | 05:50 PM
moosefist's Avatar
Default 97 a4 left me stranded today... lots of vag codes....
My car is a 1997 a4 2.8L 12v
I was driving to work this morning and my car lost power while i was shifting. It was as if pressing on the gas pedal did nothing. The car idled fine, but it would not rev up but barely for a second then it went back to idle. The car has recently developed a small leak in the water pump, but that was going to be handled next week when i do the timing belt. Also the car hasn't felt as responsive as normal lately, and this morning was about 15-20 degrees colder than normal (40degrees)
I did manage to pull 7 Vag codes.
***17914.p1506 closed throttle position switch (CTP) switch-F60 does not
***16505.p0120 throttle/pedal position sensor/switch a circuit-G
16785.p0401 exhaust gas recirculation flow: insufficient detect
16545.p0161 O2 sensor heater circuit, bank 2-sensor 2
16540.p0156 O2 sensor circuit bank 2-sensor 2: malfunction
16542.p0158 O2 sensor circuit, bank 2-sensor 2: high voltage
16522.p0138 O2 sensor circuit bank 1-sensor 2: high voltage
I think the first 2 codes are related to my problem. I was going to clean my EGR next week when i was doing the timing belt, but the O2 sensors I am not sure about (could they be related to the EGR?)
Does anyone have any experience with these codes? I hope these aren't pricey repairs, because i am broke
Old Dec 1, 2009 | 06:17 PM
dragonrage's Avatar
Sounds like a bad throttle position sensor to me. They're $170 on Rockauto. Perhaps you can clean it out with electrical contact cleaner. Clean your EGR and whatever other stuff with carb cleaner. While you're in the engine bay and cleaning stuff out, clean out your suction pump as well with carb or brake cleaner. It won't throw those codes so it's not the problem, but trust me, clean it. It looks like this: http://www.ecstuning.com/Audi-B5_A4-...tion/ES252639/
Deal with the O2 and possibly the EGR code (if cleaning doesn't fix it) after the TPS codes are fixed.
The closed throttle position switch is integrated with the TP sensor. You can test those with a multimeter.
Old Dec 1, 2009 | 11:53 PM
moosefist's Avatar
do you know of any instructions of where or how to get to the throttle position sensor? Unfortunately i don't have a bentley manual...
striker3000s
Nov 18, 2010 11:44 AM
jgurland
Jan 29, 2008 08:51 PM
p_bay
Sep 16, 2007 10:39 PM
dscott
Feb 3, 2007 03:56 AM
SMOKIESMAN1
Aug 26, 2006 05:22 AM
