97 dv
Old Sep 1, 2008 | 05:28 PM
paintballpimp765's Avatar
haha yea i just put an aftermarket dv on my 97 yesterday. was expecting to get it done in 5 minutes like my old saab...didnt know what i had comin to me lol. i went ahead and took the rubber intake pipe off that made it a little easier. i didnt take the headlight or anything like that off tho. definately worth it in the end tho
Old Sep 1, 2008 | 05:31 PM
onepoint8tee's Avatar
I didn't take the headlight out. I don't see how it makes it any easier.
Old Sep 1, 2008 | 05:54 PM
Jc61990's Avatar
i did when i did it on my 99.5 cuz i was following the tutorial, then after i got under my car and saw the old 1 staring me in the face i was like wow ok, that was un necessary
Old Sep 1, 2008 | 07:41 PM
ghost6303's Avatar
Originally Posted by onepoint8tee
It's a tight fit with an aftermarket dv. It sits within milimeters of the rad. fan.
and the hose that connects the after-turbo intake hose to the DV is basicly in contact with the a/c compressor drive belt. my hose poped out of the bracket that holds it away from that belt and it rubbed thru in a few seconds.
Old Sep 1, 2008 | 07:48 PM
So 98 uses this inconvenient dv location as well?
Old Sep 1, 2008 | 10:00 PM
ghost6303's Avatar
apparently so, i didnt know 2000+ models had it easier then me
my 98 is the same as it shows in those pics. also removing the headlight does make it very slightly easier to get screwdrivers in there and such, but pretty much when i need to take out my DV, i have to first remove the pancake valve, n75, MAF, crappy heatshield i made, and turbo inlet hose to get to it.
pretty much if you dont take all those parts off, your fingers will be bleeding by the end of it. the headlight is not absoloutely necessary tho.
Old Sep 1, 2008 | 10:03 PM
Jc61990's Avatar
hah! that sucks. at first after i installed mine i thought i put it in the wrong place because it didnt match up to the pictures in that tutorial and it was way to easy
Old Sep 1, 2008 | 10:22 PM
  #18
But once it's in it should be good for the life of the engine. I can unscrew the top of my dv while installed pretty easily to get the piston/spring/seals out for servicing.
