97 fwd seems sooo much faster than 01 quattro
Old Apr 21, 2010 | 09:41 PM
MartinCieslak1's Avatar
Default 97 fwd seems sooo much faster than 01 quattro
Today I drove a 2001 1.8t quattro and my 1997 1.8t fwd seems so much nippier and faster, they are both stock. Is there that much of a difference between fwd and quattro?
Old Apr 21, 2010 | 10:29 PM
Mike-2ptzero's Avatar
That is because the 97 FWD is going to be much lighter then the 2001 quattro. As for power the quattro will actually make 10% less power at the wheels vs a FWD making the same power at the crank. So this means that 170hp 2001 quattro is making the same power at the wheels as that 150hp 97 fwd.
97 fwd = 132whp
01 quattro = 132.6 whp
So yes the 97 feels quicker because its power to weight ratio is higher.
Now once you start making more power on those 2 cars the quatro is going to have an advantage because it will be able to put that power to the ground. Once you reach 300whp on the FWD A4 all you end up doing is spinning those 2 front tires.
Old Apr 21, 2010 | 11:17 PM
turtleboy's Avatar
There might also be the off chance that your car's engine was healthier than the quattro's.
Old Apr 22, 2010 | 10:18 AM
Yeah that is another factor, but the 200 lbs difference is also a big factor.
Old Apr 22, 2010 | 10:41 AM
flynnr's Avatar
not to mention your car is drive by cable, as opposed to the drive by wire you mught not be used to
Old Apr 22, 2010 | 12:38 PM
dragonrage's Avatar
And yet again someone blames/bashes DBW undeservedly.
Old Apr 22, 2010 | 01:04 PM
yeah seeing that you still just push the throttle to the floor to go. lol
My time from 2001 still stands as the quickest A4 1.8t K03 setup, so DBW cant be all that bad.
Old Apr 22, 2010 | 03:21 PM
flynnr's Avatar
i never said it was any faster, or slower... i just said you might not be used to it......
btw DBC ftw
Old Apr 22, 2010 | 03:32 PM
flynnr's Avatar
lol i looove how you just jump right out at me saying im bashing DBW.... i clearly only said "you might not be used to" it
someone woke up on the wrong side of the **** *****
Old Apr 22, 2010 | 03:53 PM
btw DBC ftw
You know I am just giving you a hard time
