98 2.8 QM tune up!
Old Oct 10, 2011 | 10:08 PM
Audi_B5's Avatar
Default 98 2.8 QM tune up!
I want to do a tune up on my A4... its a 98 2.8 30v QM with just over 108,000 miles and its been feeling down on power lately. So ive decided to get new spark plug wires, fuel injectors, and coil packs. also i plan on doing the fuel filter asap. i want to know what you all recommend and/or have experience with.
Old Oct 10, 2011 | 10:19 PM
Oscardeprince's Avatar
Make sure you turn off the engine before you start.
I hope you've got your DIY permit handy too.
Old Oct 10, 2011 | 10:37 PM
Audi_B5's Avatar
I'm always tinkering with my car haha so I know my way around it good... I want to know whats the best bang for the buck I can get for everything
Old Oct 10, 2011 | 10:41 PM
02quattrokev's Avatar
Disable fuel and run fuel injector cleaner directly into the fuel rail and let the car run off the cleaner only until depleted. If your timing belt and water pump hasn't been done yet i would also recommend that. Definitely an air filter, i didn't see that on your list. Also one last thing, if your car is running coil packs you wont have spark plug wires just sayin.
Old Oct 10, 2011 | 10:45 PM
Audi_B5's Avatar
Timing belt, water pump, thermostat, tensoner pulleys, and both belts were done about 5k ago. I'm also running a k&n air filter, first thing I ever bought for it lol... It's the v6 so it had coilpacks mounted in front Of the engine with the plug wires to each cylinder
Old Oct 10, 2011 | 10:48 PM
When you say down on power, has it thrown a check engine light ?
Old Oct 10, 2011 | 10:53 PM
Audi_B5's Avatar
never seen a CEL since ive had it... but it just doesnt feel and sharp and quick as it used to be... and it feels like its getting a little worse more and more. the all the ignition parts are stock except for the plugs which i replaced with ngk laser iridium's not to long ago
Old Oct 10, 2011 | 11:03 PM
IanWPB's Avatar
Originally Posted by Audi_B5
It's the v6 so it has an ignition coil mounted in front Of the engine with the plug wires to each cylinder
Fixed
Old Oct 11, 2011 | 07:54 PM
ImTheDevil's Avatar
Skip the wires - they almost never go bad on these cars. What gap did you set on the plugs? It should be .032". Change fuel filter, clean the throttle body, clean the PCV corrugated tube, clean the air filter, adjust tire pressures as needed. See if some of that helps.
Old Oct 12, 2011 | 02:13 PM
jdahlen24's Avatar
Don't forget to change the in-cabin air filter, and it wouldn't hurt to at least check the condition of your vacuum line hoses and replace those as needed.
