98 a4 2.8 quattro 5 speed. Replacing rear left wheel hub bearing
Old Sep 10, 2011 | 10:07 PM
b5quattro's Avatar
Default 98 a4 2.8 quattro 5 speed. Replacing rear left wheel hub bearing
I am currently trying to replace my left rear hub bearing. I almost have the spindle off but im having trouble getting it completely off the car. Can any one help me out.. Im having a hard time removing the bolt to the far right.. And im also having trouble removing the wire attached to the spindle on the left... Please help
Old Sep 11, 2011 | 08:13 AM
redmond1501's Avatar
Are you having trouble with the bolt that spins freely? I used a really thin set of vice-grips to hold the bolt while removing the nut and eventually was able to get it out.
When I did the other side, I found that removing the spinning bolt earlier in the process (instead of last) made a huge difference.
As for the speed sensor wire, I had one that came right out and one that was completely seized inside the spindle. In the case of the seized wire, I had to cut it and buy a replacement off eBay for $15 EDIT: because I was switching out the whole spindle assembly with another one.
Note that there are two types of wires: one with a little retaining bolt and one without.
Old Sep 11, 2011 | 08:25 AM
ImTheDevil's Avatar
Leave the wheelspeed sensor installed in the hub - it won't be in the way. Pop the rear seat cushion off and unplug the sensor, and feed the wire and connector out through the bottom of the car. For the lower trailing arm, ditto on the thin vise-grips. We actually ground down the jaws on a set of channelock pliers to fit in there and hold the shaft.
Old Sep 12, 2011 | 02:17 PM
zadeluca's Avatar
like redmond said, it might be too late now but if you loosen that nut FIRST you will have the easiest time. the ball joint will still be stuck in the spindle and it should not spin, should being the key word. if it is out of the spindle partially already, try banging the tie rod back into the spindle and then loosening the nut
Old Sep 15, 2011 | 01:51 PM
b5quattro's Avatar
i used the vice grip trick and it worked, but im pretty sure i messed up that part.. is it a tie rod? cus it def needs replacing now.. and that wire came out eventually too
Old Sep 15, 2011 | 02:02 PM
zadeluca's Avatar
^ yup, rockauto has them cheapest. actually they're on clearance there right now:
http://www.google.com/url?sa=t&sourc...BoE1-w&cad=rja
redmond1501
Nov 15, 2012 07:40 AM
A84ADATE
Nov 11, 2010 09:53 AM
frettfreak
Apr 6, 2010 02:36 AM
Jack Gray
Feb 23, 2010 08:08 AM
lacrosse22
Mar 5, 2007 02:15 AM
