A4 1.8t b5 -97, Fuel Pump, Maf
hey.
i Just Got Bought An Audi.
What is The Original Fuel Pump Good For in hp?
And if you Compare The Original one to the walbro 255/h how much does the Original Bosch Flow?
And About the Maf, From What year should i Pick up a vr6 maf from?
And Isnīt the Cennection on the Original 3Inch?
And im Thinking about iscing a Mbc To control the boost on my a4, but itīs Not Chipped, So How Much can i up the Boost Original its 0.4bar But where is the Limit when the Computer tells No?
Thanks
Thanks
the stock pump should be good to about 330 crank hp
for maf, talk to your tuner.
dont use and mbc unless you have a bigger turbo
why does any of this matter if you are completely stock?
Ok, Thanks. But do you know How much It flows compared to the wallbro 255 L /H?
Im Converting to Ethanol my using saab 9000 red injector Bosch 431 wich flows 354cc on 3 bar.
Then I do not want to chip the Car before i put a bigger intercooler and a K04 in the car.. thatīs Why im Upping with mbc Until i got money for a K04 and intercooler...
So do anyone know When the Ecu says No? original is 0.4bar... 0.7bar maybe?
If you donīt know bar only psi.. then donīt wry i can convert it..
skihigh2299
Oct 11, 2015 05:54 PM
jsethwerner225
Nov 14, 2014 01:55 PM
DJmart
Aug 3, 2013 11:08 AM
