A4 1.8t b5 -97, Fuel Pump, Maf
Old Jul 4, 2012 | 06:02 PM
superantew's Avatar
Default A4 1.8t b5 -97, Fuel Pump, Maf
hey.
i Just Got Bought An Audi.
What is The Original Fuel Pump Good For in hp?
And if you Compare The Original one to the walbro 255/h how much does the Original Bosch Flow?
And About the Maf, From What year should i Pick up a vr6 maf from?
And Isnīt the Cennection on the Original 3Inch?
And im Thinking about iscing a Mbc To control the boost on my a4, but itīs Not Chipped, So How Much can i up the Boost Original its 0.4bar But where is the Limit when the Computer tells No?
Thanks
Old Jul 5, 2012 | 12:24 PM
redline380's Avatar
Legal Moderator
the stock pump should be good to about 330 crank hp
for maf, talk to your tuner.
dont use and mbc unless you have a bigger turbo
why does any of this matter if you are completely stock?
Old Jul 6, 2012 | 06:18 AM
superantew's Avatar
Ok, Thanks. But do you know How much It flows compared to the wallbro 255 L /H?
Im Converting to Ethanol my using saab 9000 red injector Bosch 431 wich flows 354cc on 3 bar.
Then I do not want to chip the Car before i put a bigger intercooler and a K04 in the car.. thatīs Why im Upping with mbc Until i got money for a K04 and intercooler...
So do anyone know When the Ecu says No? original is 0.4bar... 0.7bar maybe?
If you donīt know bar only psi.. then donīt wry i can convert it..
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
jsethwerner225
Nov 14, 2014 01:55 PM
DJmart
Aug 3, 2013 11:08 AM
Luisthehomie
Oct 1, 2012 05:24 PM
