A4 1.8T Quattro clicking..why??
Old Sep 22, 2012 | 10:49 PM
  #41
Pbcrazy's Avatar
Solid 3-5 seconds of cranking, sometimes I don't think it is going to start. I think it's the fuel pump relay though because the fuel pump never cuts off when priming, but I don't know eh that would make it take long to start
Old Sep 23, 2012 | 07:53 AM
  #42
jonbonesjones's Avatar
Moderator
If its not cutting off its probably flooding. Try holding the pedal all the way to the floor then turning the key.
Old Sep 23, 2012 | 05:57 PM
  #43
Pbcrazy's Avatar
Holding the pedal doesn't help, any other ideas? And how long can I wait before replacing the cct?
Old Sep 24, 2012 | 09:06 AM
  #44
Moderator
depends how long you want your car to last.
Old Sep 24, 2012 | 09:50 AM
  #45
McGovs2.7TB5's Avatar
Bye Bye valves if the cct breaks. i replaced it on my A4 with similar symptoms that you describe before any thing bad happened. On my S4 I had no warning that it was going and now I have new valvetrain in the 2.7.
Old Sep 24, 2012 | 09:49 PM
  #46
Pbcrazy's Avatar
Ok sounds like I'm going to buy a new cct! Anybody know a good DIY for it?
Old Sep 24, 2012 | 10:32 PM
  #47
Moderator
you need the tool also. its pretty self explanatory not much to it.
Old Sep 26, 2012 | 07:18 PM
  #48
Pbcrazy's Avatar
Any DIY's for it? Or do I just pop off the valve cover and just go from there?
Old Sep 26, 2012 | 07:45 PM
  #49
Nemick's Avatar
I'm not sure that this applies, but read it anyway.
https://www.audiforums.com/forum/diy...g-belt-174109/
Old Oct 20, 2012 | 12:11 AM
  #50
Pbcrazy's Avatar
Ok so I went to replace the cct today and the chain is very tight, I doubt it's possible to get it any tighter. So I don't think it's the cct. What are the other options? No oil pressure light, clicking gets worse as the car warms up, and it looks fine under the valve cover, no sludge buildup at all that I can see
