A4 1.8TQ Cold air/ Intake opionions
Old Oct 4, 2012 | 02:26 PM
Pbcrazy's Avatar
Default A4 1.8TQ Cold air/ Intake opionions
So I know they don't do a whole lot but which intake would be better for my 1.8TQ Quattro (specs in sig) I want a carbonio but I'm broke. Here's this one that a guy did:
VWVortex.com - DIY: Cone Intake for $80 Cdn.
Then here's a k&n legit cold air
K&N 57-0515 57i Series Induction Kit Cold Air Intake Easy To Install | eBay
Which one would be more efficient/powerful? I can afford either so I just want the best choice
Old Oct 4, 2012 | 04:41 PM
MetalMan's Avatar
The ebay link you listed is for the 2.8 engine.
If your goal is power (based on your current setup), then doing an intake will not provide noticeable gains. Heck I sometimes switch between a cone filter and a stock airbox with high-flow filter (both with a proper BlinkTek heatshield) and notice no difference other than noise.
Carbonio also won't have noticeable gains on a stock turbo.
Old Oct 4, 2012 | 06:00 PM
Pbcrazy's Avatar
Well I'm going to get a ra4 clutch and a ko4 turbo pretty soon, what is the advantage to the heat shield? If that something I should consider with the stock air box?
Old Oct 5, 2012 | 12:47 AM
mk4cam's Avatar
Even with a k04 the stock box will do.
I did my own intake similar to the one you linked too on vortex. I used and aFe cone filter and connected it straight to the maf. If your doing cone then a heat shield is a must or else you will heat soak like crazy with the filter inches from the exhaust. They are easy and cheap too make or you can buy a blinktek like stated above.
Old Oct 5, 2012 | 12:51 AM
Subarashī Kao's Avatar
why spend so much on a filter air intake etc they are pointless on stock cars ..and if you still want one just make it like that other guy said they are so cheap to make and easy and heat shield is a must true that.
Old Oct 5, 2012 | 09:09 AM
McGovs2.7TB5's Avatar
I've read the A4 air box is sufficient up to 300whp, unless you want to hear the turbo more save your money for something else. I'd say your $100 would be better spent on a boost gauge.
Old Oct 5, 2012 | 11:24 PM
mk4cam's Avatar
I felt reason for pulling the stock box was more for engine bay room and makes for easier filter changes. Thats about it. You will not feel 1hp of power difference and if done incorrectly you will be losing hp.
Old Oct 6, 2012 | 03:36 PM
howardfootball's Avatar
Don't bother with the K04. Just go with a Frankenturbo. Nearly identical price, but the FT offers significantly more power. And keep your stock airbox and do the Darintake mod. That is cutting holes the bottom of your airbox and then cutting matching holes in the fender liner.
lukestaah
Jul 28, 2012 11:26 AM
fcp4life
Jun 19, 2011 02:05 PM
urbnmat9
Apr 8, 2008 08:42 AM
AudiFast
Jul 8, 2007 01:45 AM
