a4 2.6 se auto idel overheating help
Old Feb 12, 2008 | 01:12 PM
mdub's Avatar
Default a4 2.6 se auto idel overheating help
Hi got a chance to get a cheap audi a4 2.6 se automatic it has been seating for about 16 mounths a new thermostat battrey water pump has been put in but the last cupall of day she has been runing rough she starts fine butidel is 1200to 1400 rpm and when u let your foot off the gas at low speeds or put in neutrall at a red lightthe rpm serge from 1200 to about 1800 she also overheats esay have to put the heating on to cool her down from 120 back to round the 90 mark.took her to kwik fit for a diagnostic it had no falut codes but the guy said sumthing about base idel too high or poss collant temp sendor it could be a process of alimantion and kwik fit dont do that kind of stuffhas anyone gpt any experience or help thanks a lot
THANKS
Old Feb 12, 2008 | 01:27 PM
techbod's Avatar
Default RE: a4 2.6 se auto idel overheating help
coolant temp sensor simple plug and play job
Old Feb 12, 2008 | 01:33 PM
techbod's Avatar
Removing and installing parts of the cooling system[/align]Coolant pipes - overview[/align]
O-ring
â—†Replace
â—†Lubricate with coolant [/ul]
Small coolant pipe
â—†Removing and installing
=>Page 19-22. [/ul]
From heat exchanger
10 Nm
To heat exchanger
10 Nm
Large coolant pipe
=>Page 19-24. [/ul]
Coolant temperature sender -G62 [/ul]
Sealing ring
â—†Replace [/ul]
Screw plug
10 Nm
To top of radiator
O-ring
â—†Replace
To oil cooler
Electronic thermoswitch -F76
Sealing ring
â—†Replace [/ul]
O-rings
â—†Replace [/ul]
10 Nm [/ul]
[IMG]local://upfiles/12092/7D1087CF209342578A709FD48FB4FE0F.jpg[/IMG]
randos
Feb 14, 2013 09:26 AM
AudiDom
Feb 21, 2009 04:52 AM
AudiDom
Feb 20, 2009 06:22 AM
awkishi
Sep 5, 2007 12:09 PM
Mikesnewaudi7447
Mar 21, 2007 03:12 PM
