a4 b5 2001 AWM cheap interooler
Old Jul 23, 2010 | 10:17 PM
  #21
turbo kraut's Avatar
Tech Guru
i never saw any real drop in pressure with my ebay inner cooler, but i am running a race valve and have been since my first n75 died
Old Jul 23, 2010 | 11:48 PM
  #22
Mike-2ptzero's Avatar
Originally Posted by onepoint8tee
I agree with all that. There have been more than a few members in the past who have complained about more than 1psi drop with the "cheap diy" ebay style fmic that we are talking about. I think that any fmic is going to have a larger core than stock. So there is more volume to fill up and pass through before it reaches the manifold right? Does this not mean that manifold pressure will take longer (lag) to build?
Have to understand that the air is going to take the path with the least resistance. So basically at first the air is going to go from the inlet pipe straight across to the outlet pipe, then when the pressure and resistance in that part of the car starts to increase the air then again finds paths with less resistance till the core is full.
If you increase the volume of the core between point A and point B then yes there will be more lag. Lag is also increased by going with IC pipes that are too big since that decreases the air velocity.
Also have to take into account that when the air cools it gets more dense, this effects the pressure on the cold side of the core. So does how well the car flows and the velocity of the air in the hot side pipe.
Old Jul 24, 2010 | 12:13 AM
  #23
onepoint8tee's Avatar
Good points! Thanks.
Old Jul 24, 2010 | 12:26 PM
  #24
joenelson7687's Avatar
Would a 2.5" pipe for a k04 be too large?
Old Jul 24, 2010 | 12:59 PM
  #25
dahaker's Avatar
I think thats good depending on your psi. Correct me if im wrong guys.
Old Jul 24, 2010 | 01:28 PM
  #26
FASTER's Avatar
Tech Slut
I wouldn't use 2.5" piping for a ko4. Definitely too big.
Old Jul 24, 2010 | 05:02 PM
  #27
Yes seeing that I run 2.5" pipe on my A4 that is making 800chp.
For a K04 you dont need anything over 2". This is why the kits that are actually made for the K03/K04 on an A4 use a 2" pipe.
Ftejada
Feb 3, 2014 12:32 PM
KarlD.
Apr 17, 2012 03:26 PM
Killmon
Nov 21, 2011 09:29 PM
jccollins0726
Nov 26, 2010 02:38 PM
Russian Rings
Jul 4, 2006 06:55 PM
