A4 B5.5 with engine code AUG is this normal?
Old Feb 18, 2013 | 07:28 PM
David Narez's Avatar
Unhappy A4 B5.5 with engine code AUG is this normal?
ok so i bought an 01 Audi A4 1.8t quattro like half year ago so i save some money to buy me a timing belt kit. after a long research i found out that my car may well be a AWM engine because of the VIN number because my engine code say it is an AUG witch i never found such engine code for any year of Audis. last weekend i made the timing belt change, water pump and thermostat and everything fit right as it was an AWM engine. my question is, is it right to have an audi with engine code AUG form factory or previous owner change the ******* engine? is you guy think previous owner change the engine do you think i still have 170HP out of this engine or not? or is there any chances they only have change the engine head and left the AWM block? also the thermostat was by the alternator and water pump was internal not external.
any information will be helpful thank you guys.
Old Feb 18, 2013 | 07:51 PM
Mad Cow's Avatar
You say A4 but then B5.5, which one is it? AUG never came on the B5 but it did come on the B5.5 Passat, it's the basically the exact same motor except the ECU tune only gets you 150hp or so from what I've heard. Oddly enough I haven't found any difference between ECU part numbers so there might be no difference after all. I wouldn't be surprised if a couple of AUG's made their way to A4's during production though.
Dallas09's Avatar
Old Feb 18, 2013 | 08:32 PM
redline380's Avatar
Legal Moderator
They are the same thing. It will bolt right up. Afaik the only difference is the ecu tune. I know because I was the author of that thread. Not to mention the Aug block and crank are in my car right now
Old Feb 18, 2013 | 10:58 PM
sorry i mean A4 B5, and if AUG are tune different why i still get 10 PSI and 12 PSI spikes isn't suppressible the AUG are tune to boost at 8 PSI? also i think AUG did not come with VVT and my engine has the solenoid for the VVT. i just want to know if there any chance i have the AUG and still getting the 170HP out of it.
Old Feb 18, 2013 | 11:01 PM
how much HP are you getting with that engine? and if i remapped/chipped it do i still get the same HP and torque as the AWM engines?
Old Feb 18, 2013 | 11:44 PM
redline380's Avatar
Legal Moderator
If it was just the engine that was replaced you would still have your original Audi ecu running it. That's probably why your getting 10 psi
Old Feb 19, 2013 | 11:23 AM
Mad Cow's Avatar
Yep, or it could've been just the head that was replaced for whatever reason. Either way, the motors are identical but it is a bit odd.
Old Feb 19, 2013 | 10:31 PM
in case somebody has change the engine and left the original audi ECU do you guys think i may get more hp since AUG engines have a 9.5:1 compression against AWM with 9.3:1 compression?
Old Feb 19, 2013 | 11:08 PM
redline380's Avatar
Legal Moderator
No. Compression won't matter much in your case. If anything you might see a bit more fuel economy. If you did see power gains, it would have to be with high octane fuel and a tune for it
