A4 loosing Coolant
Old Dec 1, 2008 | 04:02 PM
legends99va's Avatar
Question A4 loosing Coolant
My son has a 1997 A4 1.8T with about 135k on the ODO. The heat was not working so we flushed the system with clean water by removing the heater hoses and running water through the system until it ran clear. We also flushed the heater core the same way. Since then the heater has been great but we started loosing coolant from the 2 fittings on the turbo. Are there Orings on these fittings that can be repalced? If not what ideas do you have?
Thanks
Old Dec 1, 2008 | 11:41 PM
Tweaked's Avatar
If I recall correctly, there is a crush gasket on each fitting. They are most-likely best sourced from the dealer.
CSB51
May 26, 2015 05:23 PM
bboylawless
Oct 20, 2014 09:51 PM
tlbjornson
Aug 22, 2014 02:16 PM
scottkelly85
Aug 24, 2012 08:30 PM
cobrad4
Jul 26, 2011 11:52 AM
