A4 Quattro 96 2.8L - engine tuning q.
Old May 11, 2008 | 11:08 AM
daniko's Avatar
Default A4 Quattro 96 2.8L - engine tuning q.
I have a A4 Quattro 96 2.8L. my q is that what kind of engine tuning can i make on this car?
Thanks.
Old May 11, 2008 | 12:04 PM
01A4T's Avatar
Default RE: A4 Quattro 96 2.8L - engine tuning q.
nothing........
Old May 11, 2008 | 12:30 PM
CAB509's Avatar
6th Gear
ORIGINAL: 01A4T
nothing........
yes, he is correct, about all you can do is exhaust, intake, electric fan upgrade, and then if you are lucky enough and can find some of Mance's pats (like TBs and hi flow MAF's) then you can gain a little bit and smooth out the power but basically you are stuck with the 176CHP that the 96 comes with.
Old May 11, 2008 | 12:43 PM
01AudiA4's Avatar
^ Do they even make High flow MAF's for our cars?
Old May 11, 2008 | 03:08 PM
beem's Avatar
If you want to spend a lot of money try PES for a supercharger kit. It boosts the power a lot, but"$". B.
Old May 11, 2008 | 04:08 PM
MrFlippant's Avatar
^Won't work. PES kit is for the 30v DOHC 2.8 V6, which uses a Bosch ECU. The 12v SOHC 2.8 V6 in 1996-97 A4's uses a Hitachi ECU which cannot be reprogrammed, so to make the PES S/C work you'd have to implement a piggybacked standalone engine management system. Too expensive to be worth the bother.
Old May 11, 2008 | 05:40 PM
hb972.8q's Avatar
look here for all 12 v info http://forums.audiworld.com/12v/pages/1.phtml
ECS Tuning
Feb 2, 2015 03:21 PM
harryb5a4
Jun 6, 2014 12:37 PM
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
