A4 warning lights
I recently acquired a 1998 audi a4, FWD manual car. It has the ABS, brake, and airbag light on. I hooked up the VAG thing and here is what i got:
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 401610km/249548miles
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Part No: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D02
Coding: 06001
Shop #: WSC 06435
VCID: 3D7FC4551DE1
3 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-10 - - - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04142
Shop #: WSC 06435
VCID: 29570005F969
4 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 930 LX
Component: B5-KOMBIINSTR. VDO D10
Coding: 06242
Shop #: WSC 07330
VCID: 8F23CE9DE7CD
No fault code found.
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D05
Coding: 16140
Shop #: WSC 06435
VCID: 4081BDA16A13
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
VCID: E0C1DD214AD3
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio D01
Coding: 00205
Shop #: WSC 06435
VCID: DDBFE4D57DA1
End ---------------------------------------------------------------------
Would these be causing my lights to come on and if not, what do i need to do to fix these errors or are they not a big deal.
I do have an exhaust leak im fixing this week as well. I have searched and found that most of the ABS/ brake lights are from the module up front needing to be replaced for it. Just thought id post up my results and see what else i need to do. Im trying to create a list of things im needing to do and how much its going to cost.
Coding: 06001
Shop #: WSC 06435
VCID: 3D7FC4551DE1
3 Faults Found:
Coding: 04142
Shop #: WSC 06435
VCID: 29570005F969
4 Faults Found:
Coding: 06242
Shop #: WSC 07330
VCID: 8F23CE9DE7CD
Coding: 16140
Shop #: WSC 06435
VCID: 4081BDA16A13
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06435
VCID: E0C1DD214AD3
Coding: 00205
Shop #: WSC 06435
VCID: DDBFE4D57DA1
First off, clear all codes. See which codes come back, my guess is the HVAC codes won't come back, and most if not all of the central locking codes won't come back. ABS/brake and airbag lights won't be cleared by clearing codes.
Looks like you'll need your ABS module rebuilt, considering that it didn't come up on the auto-scan. So start with that. Prior to having my ABS module rebuilt I wasn't able to access the airbag control module, similar to you, so it's likely that once your ABS module is rebuilt you can find out the cause of the airbag light.
You don't have to buy a new one... You would have to buy the whole ABS pump with the module and that would cost $700+.
I had my ABS module repaired for $100:
CHEAP Bosch 5.3 ABS REPAIR VW Passat Audi A4 A6 A8 S4
Others have used Module Master:
ModuleMaster | Services | ABS Modules
But I think it costs $150.
It will be fine! In fact right now you are basically driving without ABS, so if you slammed on the brakes your wheels would lock up.
Usually it is recommended to cover up the ABS pump while the ABS module is removed (if you plan on driving the car). This will prevent debris from entering and messing things up. Also you'll want to cover the ABS module while it's in transit, and make sure to wrap it well.
