about to purchase labree hfc...
Old Feb 18, 2009 | 07:36 AM
fumoazul99's Avatar
Default about to purchase labree hfc...
The current exhaust system i have is magnaflow from the flex pipe back... so from the flex pipe to the opposite side is all stock... would there be anything else that i would need to get in order for my mechanic to replace the stock cat?
thanks
Old Feb 18, 2009 | 01:34 PM
jeffha4's Avatar
Labree should be a direct bolt on replacement. All sizes are the same as stock, and already has ports for sensors. Unless you needed new bolts or something, but your mechanic should have those on hand. Or extremely easy access to the proper sizes.
Old Feb 18, 2009 | 02:31 PM
nova_ss672001's Avatar
i would get new bolts, only the bottom ones, because you get some but the ones i got were crap and looked cheap and actually snapped 2 out of 3....
also i would replace the gaskets in there..
and if you have some extra money replace the O2 sensors if you are over 100k miles...
and you might want to get a bigger downpipe and flexpipe as well, otherwise you wont feel the difference as much
chowmouse
Jul 1, 2011 10:04 AM
nova_ss672001
Jan 12, 2009 04:20 PM
asurugger
Mar 8, 2008 04:38 PM
futebol3
Nov 19, 2006 05:02 PM
Ports6689
May 9, 2006 12:47 PM
