ABS on brake flashing
Old May 25, 2013 | 02:39 PM
lpgitech's Avatar
Default ABS on brake flashing
recently my abs turned on and brake light is flashing. It turns on and off when i drive. I checked it with VCDS and ABS has no codes. Any idea what could be causing this? is my abs module dieing?
Old May 27, 2013 | 06:40 PM
CryptoStorm's Avatar
break pedal switch.. your car will shut off the abs and traction control if the switch isn't working properly.. its about $60 at any auto parts store, but they have to get it from the dealer so it will take a few days to get..
Old May 28, 2013 | 12:38 AM
ImTheDevil's Avatar
That combination of lights, along with 3 beeps on startup, is the indication that the ABS module is dying.
Old May 28, 2013 | 02:30 AM
The break lights flashing or doing anything other then what they're supposed to is a indication of the break pedal switch.. Your computer uses the same switch to enable the abs. If it is getting mixed signalsof wwhether the pedal is being pressed or not it will simply disable the system. It will re-enable once you turn off the ignition and turn it back on.
Old May 28, 2013 | 09:00 PM
lpgitech's Avatar
I rescanned by abs with vcds again and this time it came up with code 01203 Electrical Connection between ABS and Instrument Cluster 03-10 - No Signal Intermittent
Old May 28, 2013 | 09:38 PM
B5 Audi's Avatar
THIS^^
just replaced the abs module in my s4
Old Jul 27, 2013 | 09:46 AM
autofast's Avatar
does anyone know if the abs module on a 1999 Passat will work on a 1999 a4 2.8 Quattro?
Old Jul 30, 2013 | 10:30 PM
hartsoe1's Avatar
Old Jul 31, 2013 | 04:24 PM
Kamil`'s Avatar
I know this may not solve your issues, but I recommend you take out the ABS sensors on each wheel hub and clean them. I remember my friend changed his axle on his Passat once and has similar problems afterwards.
Old Jul 31, 2013 | 07:45 PM
timmyaxley's Avatar
When replacing the ABS module does it need to be programmed or is it something I can do on my own? My shop doesn't have equipment for Audis
