ABS, dim LCDdisplay and smell from ventilation
Old Jun 22, 2008 | 12:30 PM
robzz's Avatar
Default ABS, dim LCDdisplay and smell from ventilation
Hi new to site and wonder is anyone can help. The following faults/niggles exist on my 1998 Audi A4 TDi 110 Avant.
Has anyone had any experience of these??
1. The yellow dashboard ABS light comes on after the car has been driven for about 1/2 hour .This stays on but goes off after the car has cooled down. The ABS hydraulic unit is warm to the touch when the light is on. I suspect it is either the wheel sensors or the unit itself.
2.The LCD display on the dash computer is very dim during warm weather. Is there a fix to this other than replacing the whole unit?
3.The car has a smell from the vent system when selected to cool. It isn't the pollen filter so suspect water is entering system somewhere I can't get to and making a smell like a wet dog! I've tried air con spray and anti-bacterial sprays and wipes to no effect.
thanks
Rob
Old Jun 22, 2008 | 12:35 PM
techbod's Avatar
Default RE: ABS, dim LCD display and smell from ventilation
catalyst fail and smell like rotten eggs, any fault codes?
Old Jun 22, 2008 | 12:37 PM
robzz's Avatar
thanks but Its not the catalyst , but definately inside the vent trunking somewhere. No fault codes
Old Jun 22, 2008 | 12:39 PM
techbod's Avatar
could be time to change the air con filter
Old Jun 22, 2008 | 12:42 PM
robzz's Avatar
Don't think so as It only smells when diverted to 'fresh air' with air con off...........
Old Jun 22, 2008 | 01:15 PM
hiwords's Avatar
the dimming can't be fixed. just be greatful that you're not missing pixels. get the fault codes read for the abs
Old Jun 22, 2008 | 03:01 PM
david9999's Avatar
Check that the drain for the water condensation in the AC is not plugged.
other possible cause could be leaking heater core. are you slowly loosing coolant?
2ducs
Jun 23, 2014 05:45 PM
ljcsgrier
Oct 31, 2011 12:17 PM
arlopez05A4
Jan 30, 2010 05:35 PM
beachchair
Jan 29, 2008 02:39 PM
theguy1084
Feb 20, 2007 10:35 PM
