ABS Module Fix
Old Nov 14, 2008 | 06:37 PM
akielb's Avatar
Yep everything will work just like it is now, just cover everything while your module is getting rebuilt - follow the DIY available @ audidiy.com for ABS controller replacement. Your car will act the same as it is now.
Got my ABS module back from Modulemaster.com on Tuesday, threw it in on Wednesday night and like magic my ABS/Brake light was gone. Only issue I has was the washer bottle didn't seem to want to go back in there, but once I got it started the right way it slid right in to place.
Old Nov 15, 2008 | 11:17 AM
sidespar's Avatar
Originally Posted by viper_04649
So just to verify, if i take this unit out, the car will still be safe to drive, just be lacking ABS (which it probably is already).
Yep, that is exactly right.
Old Dec 15, 2008 | 09:18 PM
viper_04649's Avatar
did it,
Module Masters were very nice, and super quick.
BTW, you do not need to disconnect the washer fluid, just pull out the sensor plugs, drop it down, and support it on a tool box or something. Much less mess.
Old Dec 17, 2008 | 09:44 PM
mikeeboy82's Avatar
My A6 has the same problem. You can drive your car with the unit removed, just take care to tape some plastic around the connector to keep it clean and dry. If your ABS light is flashing you probably do not have anti-lock brakes(mine work intermediately)but your car is still safe to drive, you do not have to break into the brake fluid to remove the ABS ECU. If you do rebuild your own give the rest of us some step-by-step instructions.
Old Dec 18, 2008 | 08:34 AM
sidespar's Avatar
Mikeeboy82, send me an email if you'd like me to repair yours: sidespar@yahoo.com. I charge less than half of what module masters does.
nicholec
Aug 25, 2015 01:14 PM
stang32
Feb 23, 2014 10:53 AM
mtngirl
Sep 1, 2009 05:37 PM
phillyfannc
Jun 1, 2007 02:38 PM
ddd
May 26, 2007 08:51 AM
