ABS sensor question
Old Jul 19, 2008 | 01:24 AM
ImTheDevil's Avatar
Default ABS sensor question
Is there a functional difference between front and rear ABS/wheel speed sensors? I see that ECS has different part numbers for them, but I'm wondering if that's because of the length of the wire that runs from the sensor to the harness. I'd think that functionally they're the same for a B5, but I want to be sure. Anyone know of any difference between them besides wire length? TIA...
Old Jul 19, 2008 | 06:40 PM
Mattzcrazy's Avatar
Default RE: ABS sensor question
Not for sure, but I think the things are the same other than harness. Pretty positive they are at least the same size.
Old Jul 20, 2008 | 08:43 AM
ImTheDevil's Avatar
That's what I'm hoping
Old Jul 20, 2008 | 09:52 AM
techbod's Avatar
not worth the effort because it wont fit they have different fittings
Old Jul 20, 2008 | 11:55 AM
ImTheDevil's Avatar
Do you mean the plug ends that plug into the harnesses are different? Or the sensor end itself is different? If it's the harness end, I can probably splice the old connector onto the new sensor and make it work. If it's a fundamental difference in the pickup though, I doubt it can be adapted. I ask because I can get a front sensor from a friend for what is likely to be quite a bit less than the cost of a new rear sensor, not to mention he already has it and we're doing wheel bearing replacements today, so it's the ideal time to swap it.
HJ Matroni
Mar 9, 2013 11:07 AM
congsitu
Jan 23, 2012 02:27 PM
mattavant
Aug 26, 2011 08:19 AM
interlude
Aug 1, 2010 10:18 AM
AdamBlackB5
Mar 20, 2008 12:10 PM
