ABS warning light after brake replacement
Old Aug 12, 2008 | 12:54 PM
cyclistbruce's Avatar
Default ABS warning light after brake replacement
Hi,
Have just replaced the pads, discs and bearings on my rear wheels. Everything was running fine, braking perfectly, but now the ABS light has started flashing.
The braking is still fine and there is no play in the rear wheels. I used the old ABS sensor plates on the new discs and am pretty sure that I did not damage the sensors. Also, when I turn around sharp corners, there's a loud clacking noise, which is a bit worrying!
Anyone got any ideas??
Old Aug 12, 2008 | 12:59 PM
onepoint8tee's Avatar
Is the loud "clacking noise" new w/ the abs light, or was it doing that before?
Sounds like the ABS disc isn't seated right, or is bent, or the sensor opposite of the disc got dirty or something. Take the rear wheels off again and re check.
Is this Quattro or fwd?
Old Aug 12, 2008 | 03:46 PM
Its the fwd. The clacking noise came in at the same time as the ABS light.
I heard a rumour that the ABS needs resetting?
Old Aug 12, 2008 | 04:35 PM
False rumor. I still stand by what I said above^
Old Aug 12, 2008 | 04:54 PM
euro_2nr's Avatar
^ +1 check the sensor. That's the most probable problem. hehe
zzr
Nov 9, 2009 05:55 AM
rodick
Sep 8, 2008 05:48 PM
tp
Aug 18, 2004 11:37 PM
