AEB fuel pump: how much can it handle?
Old Feb 8, 2014 | 10:50 AM
vtraudt's Avatar
Default AEB fuel pump: how much can it handle?
I am running a custom setup on my AEB.
To get A/F in line, I am currently running 70 psi (still a tad lean).
How much pressure can the stock pump handle, adding the boost (say 22 psi)?
Old Feb 8, 2014 | 05:19 PM
redline380's Avatar
Legal Moderator
I wouldn't use the stock pump at anything over 4 bar, but I think some people use them up to 5 bar.
Old Feb 8, 2014 | 07:41 PM
vtraudt's Avatar
Just back from last 'dial in' run.
At 70 psi, still showing Long Term Fuel Trim of 12%.
Also overboosting.
Had misfires passed 15 psi (NGK BKR7E gapped at 0.028).
Put in MBC in parallel to N75. Dialed in at 20 psi.
Reduced gap down to 0.024.
Running fine now.
Will log MAF etc. tomorrow to see what she flows. Hoping for 200+ g/sec.
Also see how LTFT settles (will live with 10% or thereabouts).
On the other AEB, running 76mm MAF (pegged the 70mm, K04 based custom turbo with big billet wheel), I won't get by with fuel pressure alone on current injectors. Will try 440cc (on the way) and dial it in.
Hope to flow 280 g/sec when dialed in.
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
jsethwerner225
Nov 14, 2014 01:55 PM
DJmart
Aug 3, 2013 11:08 AM
Luisthehomie
Oct 1, 2012 05:24 PM
