after cat pipe
Old Feb 15, 2008 | 11:39 PM
Jamie Q.'s Avatar
Default after cat pipe
So I looked under the used audi and I see a beautiful foot of empty space where my flex pipe was.
After the cat is the flex pipe one piece or is it a pipe and then a flex pipe? The corrosion was so bad that is looks like it could have been two pieces.
How much of a bitch is it to change out that section? With the cat face humping the engine it looks like pain in the *** tight and knuckle bending.[:@]
Old Feb 16, 2008 | 12:16 AM
turbo kraut's Avatar
Tech Guru
Default RE: after cat pipe
there is the turbo, then the cat, then the flex pipe, then just pipe...... if you have 2 feet of gap you have alot of corrosion.......
if it is legal, i would do a tp, then flexpipe and have a shop make you some 2.5 in exhaust pipe all the way back to at least the stock muffler, but that is me
Old Feb 16, 2008 | 12:59 AM
hiwords's Avatar
the flex pipe is about 10" long and it is welded on. your car exhaust must have been saturated in salt or somthing lol. might as well get a custom exhasut while you're at it because you'll definitely need to cheange all the piping
Old Feb 16, 2008 | 01:08 AM
chaos92287's Avatar
only on the 2.8 its bolted on with the 1.8
xb6boix
Apr 17, 2012 09:39 PM
mizzike2555
Apr 23, 2008 05:05 AM
Hanestyle
Oct 24, 2006 04:07 AM
Mythstery
Jan 19, 2006 08:17 PM
greenday
Nov 29, 2005 03:43 PM
