Airbag codes - troubleshooting
Old Dec 15, 2010 | 07:19 PM
vtraudt's Avatar
Default Airbag codes - troubleshooting
While scratching my head what to do to the transmission, I want to start attacking the other issues with the car.
VAGcom scan shows the following Airbag codes (below). Any suggestions how/where to start?
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 D
Component: Airbag V AUDI D00
Coding: 00127
Shop #: WSC 06334
VCID: 3469E80D2EBD
4 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
01025 - Trigger for On Board Diagnostic Lamp; Malfunction
31-00 - Open or Short to Ground
Old Dec 15, 2010 | 08:55 PM
Dallas09's Avatar
You need to start by replacing your airbag computer. The 65535 is a "hard" fault that is not resettable. Some send there computer in to be rebuilt, but they often come back with the same errors or soon get the same error. My bet is you have a model 2000 or above, I believe its more common with these models. Search 65535 audi on google and you can find more information. Once you get the new computer you can fix the wire underneath the drivers seat which is likely causing the resistance error, the B+ code is probably because the battery was disconnected at some point.
Old Dec 16, 2010 | 06:23 AM
vtraudt's Avatar
Doesn't sound good. Is 'airbag computer' the official term (when I want to search for the part, look up location in Bentley, etc.)?
Old Dec 16, 2010 | 06:28 AM
vtraudt's Avatar
Default Airbag 65535 ICM Memory Error - Wiki
From Rosstech Wiki:
Possible Causes
  • Control Module housing leaky > Control Module wet
  • Wiring from/to Control Module faulty
  • Control Module faulty
Possible Solutions
  • Check/Clean Wiring from/to Control Module
  • Replace Control Module
May since it is "intermittent", there is still hope to fix instead of replace the airbag module?
Old Dec 16, 2010 | 07:27 AM
vtraudt's Avatar
Default Airbag Control Module 8A0 959 655 D
Looks like airbag control module is a common term (not sure yet what Bentley calls it).
My part no is (does the last letter matter?)
8A0 959 655 D
Seems like Bosch part no
0 285 001 039
Old Dec 16, 2010 | 12:19 PM
MetalMan's Avatar
That sounds like the right one. Funny thing, I've got that exact module sitting right next to my hand... The Ebay seller I got it from was supposed to send me 8D0 959 655 D (paid $200), so I have to send this one back. However, you can pick up the 8A0 959 655 D pretty cheap on Ebay, just make sure the auction says that all airbags were intact and hopefully it should be okay (if not, send it back to the seller for a refund).
Old Dec 16, 2010 | 04:48 PM
Dallas09's Avatar
Even though it says intermittent, it still isnt resettable, even if you clear out any water or fix the bad connection. You would want to check for these problems before you replace it however, as both of those problems can cause a problem and give you that code. The code itself means the module has decided it has a problem internally. If you read further down on the page you took that quote from, it says that your only option is to replace the module.
vtraudt
Jan 23, 2023 05:54 AM
tenstringer009
Jan 1, 2014 11:03 PM
markymarc
Feb 20, 2013 12:03 PM
saved4use
Mar 9, 2008 09:15 PM
bennyc767
Dec 11, 2007 10:29 AM
