All of you with a vdo gauge...
Old May 6, 2009 | 02:57 PM
redline380's Avatar
Legal Moderator
Default All of you with a vdo gauge...
I have been reluctant to start this thread since i installed my boost gauge because the problem seems trivial but my curiosity is getting the better of me. for some reason my gauge makes a lot of noise. only at certain throttle positions though. it kinda sounds like a spring is vibrating or something. kinda like a zinggggg sound. just wondering if this is common in everybody elses gauge or maybe i got a bad one. something interesting about it though is when the car is shut off, it reads 1 in vaccum so maybe the thing isnt calibrated correctly. already tried messing around with the position of the hose. also, i kinda want a red backlight. will just any old led work?
Old May 6, 2009 | 03:36 PM
ghost6303's Avatar
that buzzing thing happens because the pressure is changing a small amount very rapidly in the intake manifold with each piston stroke. you need something like this...
http://www.boostcontroller.com/index.php?item=161
basically its a T fitting except the part that supplies the pressure to the boost gauge is a very small hole so that any variation of pressure isnt instantly seen in the gauge, which smooths out the needle and gets rid of the noise.
Old May 7, 2009 | 12:20 AM
redline380's Avatar
Legal Moderator
was completely unaware of that part. i just put a regular old t-fitting in.
anyone wanna chime in on the led question?
Old May 7, 2009 | 12:44 AM
zadeluca's Avatar
i bought my gauge from 42dd and also bought a red LED and the install kit which included the special vacuum restrictor t-fitting and have not had any problems.
any LED will work assuming you wire it properly. but, you'll be on your own trying to make sure it fits in the gauge properly. why not just buy one thats made for the gauge? IIRC theyre only like $6
Old May 7, 2009 | 01:11 AM
redline380's Avatar
Legal Moderator
6 bucks? dangggg! a regular one is like fitty cents. ill just see if i got a red one lying around and try to make that work.
Old May 7, 2009 | 11:10 AM
McGovs2.7TB5's Avatar
Mine came with a little red bulb 'condom' if you will. I'd assume it fits over the led thats in there to change the light color. I didnt use it so I can check if Ive got still and I'll mail it to you if you want it.
Old May 7, 2009 | 01:01 PM
redline380's Avatar
Legal Moderator
hey good idea. i think i got a red sharpie lyin around
Old May 7, 2009 | 06:50 PM
auditech79's Avatar
A red sharpie, genius! Im gonna do that when i get home today too
zedea
Jan 18, 2013 03:11 PM
Russell2686
Jul 8, 2009 11:55 AM
Stunter4Hire
Mar 7, 2009 12:50 PM
MC Hammered
Mar 29, 2008 12:10 PM
slackerscott04
11
Feb 21, 2007 04:46 PM
