All of you with a vdo gauge...
Subscribe
May 6, 2009 | 02:57 PM
I have been reluctant to start this thread since i installed my boost gauge because the problem seems trivial but my curiosity is getting the better of me. for some reason my gauge makes a lot of noise. only at certain throttle positions though. it kinda sounds like a spring is vibrating or something. kinda like a zinggggg sound. just wondering if this is common in everybody elses gauge or maybe i got a bad one. something interesting about it though is when the car is shut off, it reads 1 in vaccum so maybe the thing isnt calibrated correctly. already tried messing around with the position of the hose. also, i kinda want a red backlight. will just any old led work?
Reply
May 6, 2009 | 03:36 PM
that buzzing thing happens because the pressure is changing a small amount very rapidly in the intake manifold with each piston stroke. you need something like this...
http://www.boostcontroller.com/index.php?item=161
basically its a T fitting except the part that supplies the pressure to the boost gauge is a very small hole so that any variation of pressure isnt instantly seen in the gauge, which smooths out the needle and gets rid of the noise.
Reply
May 7, 2009 | 12:20 AM
was completely unaware of that part. i just put a regular old t-fitting in.
anyone wanna chime in on the led question?
Reply
May 7, 2009 | 12:44 AM
i bought my gauge from 42dd and also bought a red LED and the install kit which included the special vacuum restrictor t-fitting and have not had any problems.
any LED will work assuming you wire it properly. but, you'll be on your own trying to make sure it fits in the gauge properly. why not just buy one thats made for the gauge? IIRC theyre only like $6
Reply
May 7, 2009 | 01:11 AM
6 bucks? dangggg! a regular one is like fitty cents. ill just see if i got a red one lying around and try to make that work.
Reply
May 7, 2009 | 11:10 AM
Mine came with a little red bulb 'condom' if you will. I'd assume it fits over the led thats in there to change the light color. I didnt use it so I can check if Ive got still and I'll mail it to you if you want it.
Reply
May 7, 2009 | 01:01 PM
hey good idea. i think i got a red sharpie lyin around
Reply
May 7, 2009 | 06:50 PM
Quote: hey good idea. i think i got a red sharpie lyin around
A red sharpie, genius! Im gonna do that when i get home today too
Reply
Subscribe
