An annoying coolant leak..
Old Oct 22, 2008 | 05:38 PM
Tasteofblood's Avatar
Default An annoying coolant leak..
Hey guys, ive got a coolant leak on my 1997 a4 1.8 t. I can't really figure out where its coming from but i know that its dripping down and leaking off the transmission. Its a pretty consistent and slow leak so ive just been running off distilled water. I can't really see where its leaking from so my question is.. is there any common area's to check for leaks on the a4?
Old Oct 22, 2008 | 05:40 PM
Darkprodo's Avatar
its coming from the rear coolant flange. where the temp sensor plugs into.
very very common
Old Oct 22, 2008 | 05:52 PM
i just tried to search for pics of the flange but couldn't come up with any.
Where can i buy the part from online?
Old Oct 23, 2008 | 07:11 PM
i can't find the part online. Is this the actual term for the part?
Old Oct 23, 2008 | 09:40 PM
teamdaraptor's Avatar
the coolant flange yes. I've had quotes on mine when I thought mine was bad. Do it yourself man if you're even semi mechanically inclined. I had a quote for like 500 to do it.
Old Oct 23, 2008 | 10:29 PM
TeeterTawter's Avatar
Old Oct 24, 2008 | 01:51 PM
sweet thanks.
Old Oct 27, 2008 | 09:32 AM
transit360's Avatar
My '97 1.8T has the same problem. I replaced both the o-rings, but it's still leaking out another spot. Can you guys help?
If you look behind the rear coolant flange, there is a hose that runs up behind it. It apprears to have a plastic collar...is this a hose clamp of some kind? This is where this car is leaking currently, and i'm can't see whether it's a hose clamp, or some kind of hose fitting, or some pre-formed collar.
I'm hoping that it's just a hose clamp of some kind. Can anyone tell me what this plastic collar is? It's about 2" long and is cracked all the way down the side, and thus the hose is leaking.
Old Oct 28, 2008 | 03:22 PM
it would be awesome if someone had pics of all this stuff.
Old Oct 29, 2008 | 03:28 PM
transit360's Avatar
Here goes some great pix:
