Another headlight question
I have the pre-facelift A4, so the foglights are built into the headlight housings.
So, if I were to get these headlights, would the foglight switch become completely useless?
EDIT: Forgot to put the damn link in here. http://cgi.ebay.com/ebaymotors/ws/eB...m=360099024205
I wonder what would turn the halos on...
Can someone point me to a good pre-facelift to post-facelift foglight mod thread?
Anybody with a pre-facelift A4 ever used these kinds of aftermarket lights and figured out how to add fogs?
Yeah u can tap the foglight wire on your harness, im not sure if the post ones draw more current, if they do you could add a relay, if not you can wire direct. Use a multimeter i cant remeber which wire it is.
Very easy to do. The green/yellow wire in the headlight harness is the fog wire. There is no difference in current draw between pre- and post-facelift fogs - both are H7 bulbs. Use a wiretap to tap into the fog wire, run the wire down to the new fog, and ground the new fog in the engine bay or on the brown wire in the headlight harness. My car is a pre-facelift and I'm using facelift fogs plus depo projector lights. It works as if it left the factory this way.
You told someone else on here where you got yours on ebay, and I looked for them, but it seems the seller doesn't carry them anymore.
Well for starters, the lights on Devil's car are two piece "S4" lights, not one-piece halos like yours, so there was no trimming involved in his, whereas you'll most likely have to trim your inner fenders to get them to fit.
I haven't looked for headlights in a while, but if you check ebay occasionally that kinda stuff will show up for a few days, and you pretty much have to jump on it.
