Another suspension question
Old Apr 16, 2008 | 04:48 PM
zabranca's Avatar
Default Another suspension question
I have a 1998 a4 2.8 Avant with the sport package, which includes the sport suspension. I have spent quite a bit of time on this forum looking for information about my suspension and possible upgrades. From what I have found, my sport suspension is the same as the s4 suspension. It works well for me, but I want something stiffer and that will lower the car. At first I thought I would get some H&R race springs and upgrade the sway bars, but several people have said the race springs will destroy my sport shocks and struts. Instead of going all out and getting a coilover set, what are my other options? I looked at Bilstein's sport shocks and struts with the race springs from H&R.
Basically I want to know how much of a difference this will make, since I already have the sport suspension. Some people have said a setup like that would be jarring, but I wouldn't mind if it gave me an edge. Also what is the difference between the H&R sport springs vs. the race springs.
Any help would be greatly appreciated.
Thanks
Old Apr 16, 2008 | 07:02 PM
CAB509's Avatar
6th Gear
Default RE: Another suspension question
the difference between sport and race is the height which it drops your car and possibly the spring rate(most likely but I'm not positive). some people have run H&R Race on sport shocks, it just diminishes the life of your shocks greatly.
As for them being to stiff, it is totally preference, You need to if all possible get in a car with H&R/Bilstein's and take a ride to see if you like it or not.
hope this helps somewhat
Old Apr 16, 2008 | 07:25 PM
zabranca's Avatar
What shocks and struts would you recommend with the race springs. Or will the springs just shorten the life of almost any setup?
Old Apr 16, 2008 | 07:35 PM
CAB509's Avatar
6th Gear
either Koni or Bilstein or probably Vogtland, you would just need to make sure that they are sport shocks, which are made to take the different spring rates better of a stiffer suspension.
Old Apr 16, 2008 | 07:45 PM
zabranca's Avatar
Alright thanks. From your knowledge would a setup with sport shocks and struts with race springs be significantly stiffer than my already sport suspension?
Old Apr 16, 2008 | 07:48 PM
CAB509's Avatar
6th Gear
I've never ridden in a sport suspension but I would only assume that yes race springs would increase the stiffness a decent amount over your sport suspension. If you PM Kolbs_91, he went from Sport to Neuspeed Race springs (I think) and might be able to give you a better comparison than myself.
Old Apr 17, 2008 | 09:54 AM
RaFa's Avatar
Does any know where I can get the H&R Race springs for a good price...for my 99.5 1.8TFWD??
I have Teins and I want to change it. send me PM if you can. thanks
Csacdalan
Feb 10, 2012 11:30 AM
alexmurphy
Jan 18, 2012 02:12 PM
hahaha251251
Jun 5, 2008 01:56 AM
rjkotler
Apr 1, 2008 09:19 PM
m5racer
Feb 18, 2007 12:08 AM
