Any help would be highly appreciated....
i Have a 1997 Audi A4 1.8T Quattro , Manual
Can anyone answer these questions?? I have tried searchiing the net but have come up with nothing. yet.. Any help would be greatly appreciated. Thanks
4. What type of ignition system does your car run- where is the crank
angle sensor (CAS) or distributor trigger wheel and what type is it
(Optical/LED Sensor? Hall Sensor? VR Sensor?)
5. How many teeth/windows/slots and what orientation does the CAS, crank
trigger, and/or distributor wheel have? (any missing? all evenly spaced?)
7. Does this engine have a fast idle valve (IAC)? If so, how many wires
are connected to it? Do you know if it is an on/off, pulse width
modulated, thermal, or stepper type?
ORIGINAL: Babz
Can anyone answer these questions?? I have tried searching the net but have come up with nothing. yet.. Any help would be greatly appreciated. Thanks
Ive never installed an aftermarket ECU before and thought it would be better getting a megasquirt
ecu over a chip because i want to go BT later on. So i was asked a few questions but could not answer these ones. Il give the guy a call and see what he is on about. If you have any comments on Megasquirt Ecu then please do give your input....
there are a ton of diy's on it, but you have to know what you are doing to get into it
here is the google search... i know computers, but i would not mess with my cars computer
http://www.google.com/search?sourcei...megasquirt+ecu
ORIGINAL: Babz
I can build car from scratch but havent worked on an german car before, so thought there might be more to it..
