Any help would be highly appreciated....
Old Feb 13, 2008 | 02:00 AM
Babz's Avatar
Default Any help would be highly appreciated....
i Have a 1997 Audi A4 1.8T Quattro , Manual
Can anyone answer these questions?? I have tried searchiing the net but have come up with nothing. yet.. Any help would be greatly appreciated. Thanks
4. What type of ignition system does your car run- where is the crank
angle sensor (CAS) or distributor trigger wheel and what type is it
(Optical/LED Sensor? Hall Sensor? VR Sensor?)
5. How many teeth/windows/slots and what orientation does the CAS, crank
trigger, and/or distributor wheel have? (any missing? all evenly spaced?)
7. Does this engine have a fast idle valve (IAC)? If so, how many wires
are connected to it? Do you know if it is an on/off, pulse width
modulated, thermal, or stepper type?
Old Feb 13, 2008 | 12:57 PM
99A4NOW's Avatar
Default RE: Any help would be highly appreciated....
Riddle me this... why do you want to know these things?
Old Feb 13, 2008 | 03:20 PM
01afour's Avatar
....almost sounds like what you would need to kno to take one...
Old Feb 13, 2008 | 03:33 PM
techbod's Avatar
ORIGINAL: Babz
Can anyone answer these questions?? I have tried searching the net but have come up with nothing. yet.. Any help would be greatly appreciated. Thanks
I know all the answers to this but its not appropriate to modern cars because your integrating old with new and it doesnt work like that
Old Feb 13, 2008 | 03:36 PM
techbod's Avatar
newer cars dont use the hall sender
Old Feb 13, 2008 | 06:26 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: 01afour
Old Feb 13, 2008 | 11:47 PM
Babz's Avatar
Ive never installed an aftermarket ECU before and thought it would be better getting a megasquirt
ecu over a chip because i want to go BT later on. So i was asked a few questions but could not answer these ones. Il give the guy a call and see what he is on about. If you have any comments on Megasquirt Ecu then please do give your input....
Old Feb 14, 2008 | 08:44 AM
Tech Guru
there are a ton of diy's on it, but you have to know what you are doing to get into it
here is the google search... i know computers, but i would not mess with my cars computer
http://www.google.com/search?sourcei...megasquirt+ecu
Old Feb 14, 2008 | 12:30 PM
Babz's Avatar
I can build car from scratch but havent worked on an german car before, so thought there might be more to it..
Old Feb 14, 2008 | 07:09 PM
Leifer's Avatar
ORIGINAL: Babz
You can't build a car then. You can build half a car, like a Ford, where brakes and steering is optional.
