anyone good with sound systems?
Old 09-07-2008, 08:38 PM
ryanylva's Avatar
If you are real impatient youcan cut as much of the ground as you can and put it to the nut holding down your spare tire haha. But I would try to get to the original connection
Old 09-07-2008, 08:59 PM
LightOnA4's Avatar
ok i got to it, took the bottom part of seat out.
pretty easy actually lol.
tightened it down.
still notta.
the thing thats pissing me off is that im not getting the power light to come on at all now on the amp.......
whats next?
and o ya the ground cord was like only 2 1/2 ft long so i cant really find a good new ground....
suggestions??
Old 09-07-2008, 09:22 PM
ryanylva's Avatar
Hmmm...You checked the fuse on the amp and the inline fuse under the hood? Did you check the battery connection? Also try keeping the power on and touching the ground to different metal points
Old 09-07-2008, 09:31 PM
hiwords's Avatar
i used the bolt that holds the clip thingy that holds the carpet down in the trunk as my grounding point. def put up some pix so we have more of a bearing on your setup. just copy the link from photobucket
Old 09-07-2008, 10:20 PM
LightOnA4's Avatar
ok here are some pics
this is of the new grounding spot i got and still doesnt work!!
this is my amp setup
old grounding spot, was held down by a screw and lock washer. drilled and paint scrapped away by installers.
wtf!!! lol
im still not getting the power light to come on now since i started messing with it.
Old 09-07-2008, 10:35 PM
LightOnA4's Avatar
damn no help?? lol
**** im gonna have to bring it somewhere and have them rape me on charges to fix it.
Old 09-07-2008, 10:59 PM
Audi_Skydiver's Avatar
Check the fuse on the power wire to the amp.
Josh
  #18
Old 09-07-2008, 11:29 PM
carcrzy24's Avatar
start with the fuse in the front then the one on the amp the ground should be good cause i have mine grounded to the bolt holding that clip that holds the carpet ill bet its the remote wire i have the same problem putting my amp in last time got power but then shut off and turned out to be a loose connection of the remote wire so check that too
  #19
Old 09-07-2008, 11:32 PM
LightOnA4's Avatar
all fuses are good, i double checked them.
the problem with the remote wire is that its on my head unit, and i have no idea how to get the new one out lol. for that indash kit for 99 b5 a4's for aftermarket head units, is there a key for them??
or do i have to take the dash apart??
and how simple is that?? lol
  #20
Old 09-07-2008, 11:45 PM
ImTheDevil's Avatar
Is it grounded to bare metal or painted surfaces? If they're painted, that'll easily give you the weak ground. The metal underneath the ground ideally should be sanded or at least scraped clear to give you straight contact with bare metal. If tha'ts not feasible due to location, find another bolt or mount for the ground, scuff through any coatings, down to bare metal, and reground the amp.
Quick Reply: anyone good with sound systems?
