Anyone know hubcentric ring size?
Old Jun 6, 2008 | 10:43 AM
nflea7's Avatar
Default Anyone know hubcentric ring size?
I have a 96 A4 quattro, I got 17" aftermarket rims I got used they didn't come with rings and I know there is a gap in the center boar. But how big is the gap? I am guessing the rim is 70mm but what size is the ring on the rotor? If anyone has done this and can post what size ring I need its greatly appricated. My car shakes wicked bad over 60mph and it didn't with the stock rims. Thanks
Old Jun 6, 2008 | 11:03 PM
Redrum1's Avatar
Default RE: Anyone know hubcentric ring size?
The size of the hub is 57.1 mm. So thats your inside size for the concentric rings. What you can do in the meantime is jack each wheel up and loosen the bolts. Then retighten them with no weight on the wheel and the taper on the hub bolt will help center the wheel.
Good Luck...
Audacity
Apr 12, 2011 10:53 AM
Mr. Phil
Mar 8, 2010 09:12 PM
jhsoccerodp
Dec 5, 2008 10:48 AM
Dargofinch
Sep 27, 2007 05:50 PM
