coolant flange o ring size.
have a leak from the coolant flange to the metal pipe that leads to the top of the radiator. i took it all apart today o ring looked fine, so i put it back together thinking that maybe a retorque would fix it but it didnt, must just be age getting to the oring. anyway my question is anyone know the size of the oring that i need?
no don't do it. the flange is not expensive. and its a plastic p.o.s. they warp thats why they leak. if you replace the o-ring your just wasting time to see that it still leaks after you have it filled back up with new coolant.
the flange itself was replaced
with the o Ring that I took out. the ring on the block side was replaced so even if I was to replace the flange I will most likely need a an o ring anyway
