Anyone put a aftermarket amp w/ stock headunit?
Old Feb 28, 2008 | 07:16 PM
discontained's Avatar
Default Anyone put a aftermarket amp w/ stock headunit?
Hey im tryin to install a new amp into my stock symphony (non bose) system. I have the rear speaker amp disconnected (mine died) and im tryin to figure out the RCA leads.. anyone have any tips/help?
TIA
Old Feb 28, 2008 | 07:21 PM
mr.cAp's Avatar
Default RE: Anyone put a aftermarket amp w/ stock headunit?
the center of the rca cable is 12v and the outside is ground
what exactly are you trying to do, if your just replacing the old stuff hook it up the same as it was.
Old Feb 28, 2008 | 07:24 PM
Yea i know that as far as i got. I cant seem to locate the wires on the plug for the factory amp. I tried the DIY but get nothing out of my sub. Plus that was for a 99 and i have a 01.5 :[ what wires on the plug are the RCA +/-
***EDIT .. im trying to hook a amp/subwoofer up to stock headunit. My factory amp burned itself up.
Old Feb 28, 2008 | 07:27 PM
mr.cAp's Avatar
ummm, i would have to see it, pics?
Old Feb 28, 2008 | 07:29 PM
my camera is at g/f's house.. umm ill expain it better i guess.. The factory amp is on the rear speaker, im simply taking the shitty amp, and removing it from the system.... then im adding a more powerful amp to the system. Im looking for the LOW LEVEL/RCA lead's (color of wire) to connect to the amp to make my sub go boom boom (haha)
what pic do you need, cuz ill draw one if i have to
Old Feb 28, 2008 | 07:37 PM
chaos92287's Avatar
you have to use a line level converter. it accepts the rca connection and has regular wires on the other end. you just hook the rca's from the amp into that and then the wires into any + and - connection on the headunit. some use the stock sub connections, others just splice into the front or rear channels
Old Feb 28, 2008 | 07:44 PM
ok but which wires do I hook into for that? using the REAR FACTORY AMP Wiring harness? the green/red one? or what.. tia
Old Feb 28, 2008 | 07:45 PM
mr.cAp's Avatar
beat me to it, damn, but yea or you can pick up a cross over to truly fine tune the sound. honestly i would chuck the speakers and pick up a nice componet system like polk, or alpine, any way here is a good site for speakers, www.millionbuy.com i use them for everything
Old Feb 28, 2008 | 07:51 PM
i have replaced all my speakers with Polk, and im running the 2 front's right now cuz the rear amp crapping out on me. I Just went and picked up the line level converter.. so here is my noob question.. what wires go in the back? i cut the stock amp harness plug off and im searching for the pre-amp's cant seem to locate them. any idea's?
oh and thanks for the help im a nub when it comes to audio
Old Feb 28, 2008 | 10:40 PM
jason955's Avatar
If you convert from speaker signal to a low frequency signal (rca) and run a sub off of it, it will not sound half as good as getting a head unit with RCA outputs built in. In an ideal system you cut off all of the low frequency signals to the tweeds and mid range speakers and send only the lows to the sub. You can't do this with the system you described.
