APR ECU Chip or K04 Turbo?
Old 02-24-2014, 11:43 PM
Parker0217's Avatar
Question APR ECU Chip or K04 Turbo?
I own a 99 Audi A4 Quattro 1.8T(Automatic) and looking for that extra HP with the best bang for my buck..so i've heard APR ECU Stage 1 or K04 Turbo upgrade are good HP gain..Which option is the best for performance and price?
Thanks
Old 02-25-2014, 01:02 AM
george1546's Avatar
Price wise get an APR ECU or any tune for that matter. As for a K04, I personally would never spend that much money in my life from APR for a K04 upgrade, biggest waste of money for the performance, If I wanted to spend thousands, I would go big and not a K04 however if you find a K04 upgrade cheap from someone, then go for it.
Old 02-25-2014, 01:43 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
^Exactly what George said.
Chipping your car is the easiest mod you'll ever do and the most bang for your buck. Can't say the same for a K04.
Old 02-25-2014, 06:37 AM
bradtyler02's Avatar
Adding a KO4 will not add power unless you get a tune to go with it. Start with the chip until that bores you, then look into a BT setup. Mike at ringer-racing.com can hook you up with some knowledge
Old 02-25-2014, 10:58 AM
swimbikerunrun's Avatar
I just got my 2000 ATW chipped for about ~$650(?) out the door. I LOVE LOVE LOVE LOVE LOVE LOVE LOVE it.
I got the APR Stage 1 chip, had to be soldered to the ECU so it took more time. Honestly, didn't even care. Spiking at 20lbs and holding at 16 is awesome.
Old 02-25-2014, 11:22 AM
Huskerbob's Avatar
Thanks
Just be careful you don't over power that slush box tranny. Chip first then K04 if you think you need it. Stock intake in any case.
Old 02-25-2014, 01:54 PM
Parker0217's Avatar
Thanks guys appreciate the help! Sounds like il be going with the APR Chip. So far ive put a K&N Cold Air Intake & Cat-back exhaust..So what kind of HP increase would i be looking at with APR Chip?
Old 02-25-2014, 02:12 PM
McGovs2.7TB5's Avatar
Old 02-25-2014, 05:18 PM
Huskerbob's Avatar
Make sure you isolate/insulate your K&N "cold" air intake from the turbo and exhaust that are about 1 inch away from it or you will have a hot air intake. Just saying. No way under hood air can be colder than grill intake air. Looks good I bet.
Old 02-25-2014, 07:03 PM
Don't forget to get a boost gauge and upgraded diverter valve.
Quick Reply: APR ECU Chip or K04 Turbo?
