Audi 1.8t MAF?
Hmmm maybe this isn't an air delivery or ignition problem... Is your fuel filter very old? Have you tried fuel injector cleaner or Seafoam in the gas tank? What gap do the spark plugs have? How old is your battery (are you sure it is good?)?
Just some ideas.
Just some ideas.
Thanks, but I`m not sure that any of this things are the problem. Gap is good(0.028), filter too. I`ve done seafoam once 40k miles ago. I`ll see what guys at service say after testing. I`m still thinking something with air delivery boost/vacuum leak or bad MAF.
One more thing. What about catalyst converter, I think that mine is clogged to some degree, maybe making problems with back pressure. Is it safe to clear metal net inside of the cat so it doesn`t restrict air coming through? Emission is not problem here...
You will get a check engine light because of "catalyst efficiency below threshold" or something like that. My car has that code right now... because of the high-flow cat. 034 Motorsport makes an O2 sensor spacer that should get rid of that code.
I`ve changed air filter. But when I unplug MAF, car is only boosting to 4psi like in limp mode, so it is hard to tell is it better. I`ll see if it drops below 4psi, because with maf it goes to almost zero psi after 5000rpm...
So only that code "catalyst efficiency below threshold" and I can ignore it, doesn`t it upset fueling or something?
Good news
Car is normal again. The problem was pipe going into the Diverter valve. Can`t believe I didn`t notice that...
Now boost is fine. In second gear 11.5psi till 5000rpm and slowing fading to something around 8-9psi at 6000rpm, this should be just right for 0.8bar chip and 187HP
Thanks for help, it wasn`t maf after all. Anyway, it`s good to know that maf is worknig fine after 140K miles and other sensor are good.
.Car is normal again. The problem was pipe going into the Diverter valve. Can`t believe I didn`t notice that...
And it is possible for a clogged cat to cause problems.
