Audi misfire
Old Oct 20, 2012 | 07:31 PM
blueridge1980's Avatar
Default Audi misfire
The other morning my wife went out to start the audi but it wouldn't start so I tried and it would turn over but not fire. I decided today I would try again and it fired but had a bad miss. Took it to local parts place and had it scaned and it was a misfire on cylnders 4 and 2 so we cleared it and I drove it around the block come back and it scanned miss fire on 4 so I bought a coil pack and had it cleared again. It run fine for about five mins and started missing again. I took it back and scanned it again and had a misfire on 4 3 and 1 so i bought a cam positioning sensor and put it on but it still runs terrible can someone please help
Old Oct 20, 2012 | 07:42 PM
Its a 2001 if this helps
Julianpnc's Avatar
spark plug wires maybe. injectors? but check the wires first cheaper
Old Oct 21, 2012 | 12:06 AM
ImTheDevil's Avatar
No wires on a 1.8T. OP, did you check the plugs? Verify that the gap is .032" and that they're not corroded or carbon-covered?
Old Oct 21, 2012 | 08:14 PM
put in new plugs today with no sucess anything else I can try before putting it in the shop
Old Oct 22, 2012 | 04:26 PM
Julianpnc's Avatar
is it the 2.8 or 1.8t?? if its the 2.8 change the wires and check the injectors also. my car also had misfires on cilinder 6 3 and 4 and i changed the spark plug wires and no more problems
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
tonyr6
Jan 15, 2010 02:26 AM
rksport
Oct 19, 2007 01:39 PM
