Audi misfiring code but doesn't seem to be missing?
Old Sep 28, 2012 | 10:47 AM
Pbcrazy's Avatar
Or should I swap coils 2 and 4 with 1 and 2?
Old Sep 28, 2012 | 10:49 AM
jonbonesjones's Avatar
Moderator
swap the two misfiring for the two that are not - clear codes - drive 20 miles -- recan. Post results
Old Sep 28, 2012 | 12:04 PM
bradtyler02's Avatar
I just replaced the spark plugs about 500 miles ago
__________________
1998.5 Audi A4 1.8T Quattro 5 Speed Manual
| Sport Package | Stage 2 Performance Tuning | Dual Scorpion Stainless Steel exhaust System | Permanant air filter | Chipped ECU | Cree Reverse lights | Full Led Interior | Led License Plate Lights |
What did you gap your spark plugs at? If you didn't, it's wrong. If you gapped to .032 like the manual says... sorry, wrong again. Because you're chipped and pushing more boost, you need to gap to .028 inches. This is most likey the cause of your misfire. But swap the coil packs anyway to see what happens.
Each cylinder is contolled by it's own coil pack, all collectively controlled by the ignition control module. If it was bad, trust me, you would know (complete loss of power and running extremely rought). And you would most likey have the misfire on cylinder 2.
Also sorry to tell you, but the AEB coil packs are the more expensive kind, about 70 bucks each.
So, break out your tools, regap your plugs to the right gap, swap 1 and 3 coil packs to 2 and 4, clear codes, drive, rescan...
Old Sep 28, 2012 | 04:06 PM
Pbcrazy's Avatar
I'll gap the spark plugs and if its still misfiring I do the coils, ill keep you guys posted
Old Sep 28, 2012 | 05:37 PM
good luck
Old Sep 28, 2012 | 05:43 PM
CCA4's Avatar
When you're re-gapping the plugs, take note of what color the electrodes are. If they're all white and crusty or wet and oily that could point to something else.
-excuse typos, sent from your mom's phone
Old Sep 28, 2012 | 06:20 PM
Pbcrazy's Avatar
I'll take pictures of the plugs when I remove them, last time I changed them they were white but I think it was from not enough fuel (I still don't think I'm getting enough even after new coolant temp sensor and fuel filter)
Old Sep 28, 2012 | 09:56 PM
  #18
Pbcrazy's Avatar
Check engine light went off while driving, but in still going to re gap the plugs
Old Sep 28, 2012 | 10:10 PM
  #19
Moderator
Clean your injectors and make sure your pump is working properly.
Old Sep 28, 2012 | 11:13 PM
  #20
mk4cam's Avatar
i was misfiring like crazy before i did a 2.0t coil upgrade. and it was all plugs causing misfire and never got a cel so i doubt its plug related. id got with the swaping coils around and see if you can narrow down the possible defective ones. if it is the coils im selling my icm, 4 brand new coils, and brand new plugs if your interested.
