B5 A4 timing question. no codes... Block 093
Old Aug 15, 2015 | 06:01 PM
Golden6969's Avatar
I like what svigote said but mostly if its idling fine when driving and if its manual and when clutching but when you are idling when stopped and its misfiring could mean a bunch of things mostly sensors just drive it untill you get a check engine light then grab a scanner at like princess auto or whatever and check it right the codes an go on line if or like you said your stumped German cars are mostly bad for I feel fine oh **** and you on the side of the road type of car
Old Aug 15, 2015 | 09:21 PM
Crookedtoad's Avatar
I have a ross-tech scanner. Misfire cyl. 1,2,3 O2 sensor code for pre cat b1s1 b2s1 electrical malfunctions. like I said before this is the only code that has no info for it in Bentley or online. I will get the code and post it. I have changed out O2 sensors I get the same code. New oem bosch and used oem bosch I have 3 sets I have changed between. all o2 sensors ohm and volt check with'in tolerance and the ECU plug ohm's and volt checks correctly to.
and it's an automatic.
Old Aug 16, 2015 | 03:52 PM
Sunday,16,August,2015,13:44:47:59104
VCDS Version: Release 14.10.1
Address 01: Engine Labels: 078-907-551-AHA.lbl
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR AT D03
Software Coding: 06251
Work Shop Code: WSC 06325
VCID: 6CD9CCAA1C6D1741A28-4B18
16 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16685 - Cylinder 1
16687 - Cylinder 3
16686 - Cylinder 2
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
P1198 - 35-00 - Electrical Malfunction
17607 - Oxygen (Lambda) Sensor Heater Circuit: B2 S2
P1199 - 35-00 - Electrical Malfunction
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
P1196 - 35-10 - Electrical Malfunction - Intermittent
17605 - Oxygen (Lambda) Sensor Heater Circuit: B2 S1
P1197 - 35-10 - Electrical Malfunction - Intermittent
Readiness: 0010 0101
Old Aug 19, 2015 | 01:08 AM
Anything? Thanks in advance.
AudiTurbo
Jan 8, 2014 10:00 PM
antolin
Jan 6, 2012 05:13 PM
MafiaBoy
Jan 7, 2011 10:42 PM
lehighwiz
May 28, 2007 04:11 PM
quattrosedan
Mar 14, 2006 07:34 PM
