backfire
Old Jan 13, 2013 | 05:48 AM
q139's Avatar
Default backfire
my audi temp sensor shows 17c when its -5c outside and car backfires when accelerating harder, are those 2 thing connected?
as far as i know less temp should use more fuel but it shows 17c...
Old Jan 13, 2013 | 07:39 AM
george1546's Avatar
Not sure about the sensor but as for the backfire, my aftermarket exhaust does that too but I think this is due to the rich condition in fuel. May be the same in your case.
Old Jan 13, 2013 | 10:36 AM
q139's Avatar
also bogging when i press accelerator and no power at high rev and at idle car bounces sometimes.
did vag com scan and also lambda data log.
it has 1.8 5v engine without turbo 92kw
GIVES THISONE
00561 - Mixture Adaptation
15-10 - Adaptation Limit (Add) Not Reached - Intermittent
LAMBDA DATALOG TIME/ VOLTAGE engine was heated up and driven, car was bogging coolant tamp was 80 and inatke temp sensor showed 17 when actually -5outside.
Sunday,13,January,2013,16:53:10:37412,VCDS Version: Release 10.6.4,Data version: 20110418
8D0 907 557 CX,ADVMB,1.8L R4/5V MOTR HS D08,
,,G009,F2,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0, G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Group 9 - Field 2,,,,,,,,,,,,,,,,,,,,,,,
,STAMP,Lambda Probe - Voltage,,,,,,,,,,,,,,,,,,,,,,,
,, V,,,,,,,,,,,,,,,,,,,,,,,
,0.24,0.680,,,,,,,,,,,,,,,,,,,,,,,
,0.50,0.555,,,,,,,,,,,,,,,,,,,,,,,
,0.76,0.275,,,,,,,,,,,,,,,,,,,,,,,
,1.02,0.120,,,,,,,,,,,,,,,,,,,,,,,
,1.27,0.085,,,,,,,,,,,,,,,,,,,,,,,
,1.53,0.105,,,,,,,,,,,,,,,,,,,,,,,
,1.79,0.110,,,,,,,,,,,,,,,,,,,,,,,
,2.05,0.090,,,,,,,,,,,,,,,,,,,,,,,
,2.30,0.150,,,,,,,,,,,,,,,,,,,,,,,
,2.57,0.410,,,,,,,,,,,,,,,,,,,,,,,
,2.84,0.210,,,,,,,,,,,,,,,,,,,,,,,
,3.10,0.190,,,,,,,,,,,,,,,,,,,,,,,
,3.36,0.245,,,,,,,,,,,,,,,,,,,,,,,
,3.64,0.230,,,,,,,,,,,,,,,,,,,,,,,
,3.92,0.770,,,,,,,,,,,,,,,,,,,,,,,
,4.17,0.805,,,,,,,,,,,,,,,,,,,,,,,
,4.43,0.805,,,,,,,,,,,,,,,,,,,,,,,
,4.70,0.355,,,,,,,,,,,,,,,,,,,,,,,
,4.95,0.175,,,,,,,,,,,,,,,,,,,,,,,
,5.20,0.200,,,,,,,,,,,,,,,,,,,,,,,
,5.45,0.170,,,,,,,,,,,,,,,,,,,,,,,
,5.72,0.195,,,,,,,,,,,,,,,,,,,,,,,
,5.98,0.705,,,,,,,,,,,,,,,,,,,,,,,
,6.25,0.775,,,,,,,,,,,,,,,,,,,,,,,
,6.52,0.790,,,,,,,,,,,,,,,,,,,,,,,
,6.78,0.755,,,,,,,,,,,,,,,,,,,,,,,
,7.04,0.440,,,,,,,,,,,,,,,,,,,,,,,
,7.32,0.120,,,,,,,,,,,,,,,,,,,,,,,
,7.57,0.405,,,,,,,,,,,,,,,,,,,,,,,
,7.86,0.780,,,,,,,,,,,,,,,,,,,,,,,
,8.12,0.745,,,,,,,,,,,,,,,,,,,,,,,
,8.39,0.745,,,,,,,,,,,,,,,,,,,,,,,
,8.66,0.610,,,,,,,,,,,,,,,,,,,,,,,
,8.92,0.275,,,,,,,,,,,,,,,,,,,,,,,
,9.19,0.125,,,,,,,,,,,,,,,,,,,,,,,
,9.44,0.125,,,,,,,,,,,,,,,,,,,,,,,
,9.69,0.125,,,,,,,,,,,,,,,,,,,,,,,
,9.94,0.170,,,,,,,,,,,,,,,,,,,,,,,
,10.19,0.185,,,,,,,,,,,,,,,,,,,,,,,
,10.45,0.100,,,,,,,,,,,,,,,,,,,,,,,
,10.71,0.080,,,,,,,,,,,,,,,,,,,,,,,
,10.96,0.630,,,,,,,,,,,,,,,,,,,,,,,
,11.24,0.835,,,,,,,,,,,,,,,,,,,,,,,
,11.51,0.790,,,,,,,,,,,,,,,,,,,,,,,
,11.78,0.310,,,,,,,,,,,,,,,,,,,,,,,
,12.08,0.210,,,,,,,,,,,,,,,,,,,,,,,
,12.35,0.810,,,,,,,,,,,,,,,,,,,,,,,
,12.63,0.800,,,,,,,,,,,,,,,,,,,,,,,
,12.89,0.785,,,,,,,,,,,,,,,,,,,,,,,
,13.15,0.785,,,,,,,,,,,,,,,,,,,,,,,
,13.40,0.675,,,,,,,,,,,,,,,,,,,,,,,
,13.66,0.500,,,,,,,,,,,,,,,,,,,,,,,
,13.92,0.715,,,,,,,,,,,,,,,,,,,,,,,
,14.20,0.115,,,,,,,,,,,,,,,,,,,,,,,
,14.46,0.645,,,,,,,,,,,,,,,,,,,,,,,
,14.72,0.740,,,,,,,,,,,,,,,,,,,,,,,
,14.98,0.090,,,,,,,,,,,,,,,,,,,,,,,
,15.24,0.070,,,,,,,,,,,,,,,,,,,,,,,
,15.53,0.045,,,,,,,,,,,,,,,,,,,,,,,
,15.78,0.035,,,,,,,,,,,,,,,,,,,,,,,
,16.05,0.040,,,,,,,,,,,,,,,,,,,,,,,
,16.33,0.850,,,,,,,,,,,,,,,,,,,,,,,
,16.61,0.770,,,,,,,,,,,,,,,,,,,,,,,
,16.89,0.855,,,,,,,,,,,,,,,,,,,,,,,
,17.17,0.740,,,,,,,,,,,,,,,,,,,,,,,
,17.44,0.080,,,,,,,,,,,,,,,,,,,,,,,
,17.71,0.045,,,,,,,,,,,,,,,,,,,,,,,
,17.96,0.035,,,,,,,,,,,,,,,,,,,,,,,
,18.22,0.030,,,,,,,,,,,,,,,,,,,,,,,
,18.49,0.030,,,,,,,,,,,,,,,,,,,,,,,
,18.75,0.030,,,,,,,,,,,,,,,,,,,,,,,
,19.01,0.030,,,,,,,,,,,,,,,,,,,,,,,
,19.28,0.030,,,,,,,,,,,,,,,,,,,,,,,
,19.55,0.040,,,,,,,,,,,,,,,,,,,,,,,
,19.82,0.535,,,,,,,,,,,,,,,,,,,,,,,
,20.10,0.760,,,,,,,,,,,,,,,,,,,,,,,
,20.35,0.880,,,,,,,,,,,,,,,,,,,,,,,
,20.61,0.875,,,,,,,,,,,,,,,,,,,,,,,
,20.87,0.855,,,,,,,,,,,,,,,,,,,,,,,
,21.13,0.840,,,,,,,,,,,,,,,,,,,,,,,
,21.38,0.810,,,,,,,,,,,,,,,,,,,,,,,
,21.64,0.785,,,,,,,,,,,,,,,,,,,,,,,
,21.90,0.790,,,,,,,,,,,,,,,,,,,,,,,
,22.17,0.790,,,,,,,,,,,,,,,,,,,,,,,
,22.42,0.715,,,,,,,,,,,,,,,,,,,,,,,
,22.67,0.330,,,,,,,,,,,,,,,,,,,,,,,
,22.93,0.140,,,,,,,,,,,,,,,,,,,,,,,
,23.19,0.110,,,,,,,,,,,,,,,,,,,,,,,
,23.45,0.105,,,,,,,,,,,,,,,,,,,,,,,
,23.71,0.095,,,,,,,,,,,,,,,,,,,,,,,
,23.98,0.090,,,,,,,,,,,,,,,,,,,,,,,
,24.23,0.085,,,,,,,,,,,,,,,,,,,,,,,
,24.48,0.090,,,,,,,,,,,,,,,,,,,,,,,
,24.73,0.095,,,,,,,,,,,,,,,,,,,,,,,
,24.98,0.100,,,,,,,,,,,,,,,,,,,,,,,
,25.23,0.115,,,,,,,,,,,,,,,,,,,,,,,
,25.48,0.150,,,,,,,,,,,,,,,,,,,,,,,
,25.73,0.380,,,,,,,,,,,,,,,,,,,,,,,
,25.98,0.600,,,,,,,,,,,,,,,,,,,,,,,
,26.23,0.700,,,,,,,,,,,,,,,,,,,,,,,
,26.51,0.745,,,,,,,,,,,,,,,,,,,,,,,
,26.76,0.725,,,,,,,,,,,,,,,,,,,,,,,
,27.05,0.365,,,,,,,,,,,,,,,,,,,,,,,
,27.31,0.155,,,,,,,,,,,,,,,,,,,,,,,
,27.59,0.125,,,,,,,,,,,,,,,,,,,,,,,
,27.86,0.125,,,,,,,,,,,,,,,,,,,,,,,
,28.12,0.130,,,,,,,,,,,,,,,,,,,,,,,
,28.39,0.150,,,,,,,,,,,,,,,,,,,,,,,
,28.64,0.110,,,,,,,,,,,,,,,,,,,,,,,
,28.90,0.360,,,,,,,,,,,,,,,,,,,,,,,
,29.17,0.605,,,,,,,,,,,,,,,,,,,,,,,
,29.44,0.840,,,,,,,,,,,,,,,,,,,,,,,
,29.69,0.670,,,,,,,,,,,,,,,,,,,,,,,
,29.94,0.350,,,,,,,,,,,,,,,,,,,,,,,
,30.20,0.760,,,,,,,,,,,,,,,,,,,,,,,
,30.45,0.800,,,,,,,,,,,,,,,,,,,,,,,
,30.71,0.795,,,,,,,,,,,,,,,,,,,,,,,
,30.98,0.815,,,,,,,,,,,,,,,,,,,,,,,
,31.25,0.825,,,,,,,,,,,,,,,,,,,,,,,
,31.52,0.735,,,,,,,,,,,,,,,,,,,,,,,
,31.79,0.400,,,,,,,,,,,,,,,,,,,,,,,
,32.04,0.250,,,,,,,,,,,,,,,,,,,,,,,
,32.30,0.165,,,,,,,,,,,,,,,,,,,,,,,
,32.56,0.150,,,,,,,,,,,,,,,,,,,,,,,
,32.83,0.270,,,,,,,,,,,,,,,,,,,,,,,
,33.09,0.530,,,,,,,,,,,,,,,,,,,,,,,
,33.36,0.815,,,,,,,,,,,,,,,,,,,,,,,
,33.60,0.815,,,,,,,,,,,,,,,,,,,,,,,
,33.85,0.790,,,,,,,,,,,,,,,,,,,,,,,
,34.11,0.715,,,,,,,,,,,,,,,,,,,,,,,
,34.35,0.225,,,,,,,,,,,,,,,,,,,,,,,
,34.60,0.205,,,,,,,,,,,,,,,,,,,,,,,
,34.86,0.695,,,,,,,,,,,,,,,,,,,,,,,
,35.12,0.670,,,,,,,,,,,,,,,,,,,,,,,
,35.39,0.115,,,,,,,,,,,,,,,,,,,,,,,
,35.64,0.095,,,,,,,,,,,,,,,,,,,,,,,
,35.89,0.480,,,,,,,,,,,,,,,,,,,,,,,
,36.15,0.815,,,,,,,,,,,,,,,,,,,,,,,
,36.42,0.745,,,,,,,,,,,,,,,,,,,,,,,
,36.67,0.235,,,,,,,,,,,,,,,,,,,,,,,
,36.94,0.085,,,,,,,,,,,,,,,,,,,,,,,
,37.19,0.075,,,,,,,,,,,,,,,,,,,,,,,
,37.45,0.080,,,,,,,,,,,,,,,,,,,,,,,
,37.70,0.075,,,,,,,,,,,,,,,,,,,,,,,
,37.95,0.080,,,,,,,,,,,,,,,,,,,,,,,
,38.22,0.090,,,,,,,,,,,,,,,,,,,,,,,
,38.48,0.085,,,,,,,,,,,,,,,,,,,,,,,
,38.75,0.520,,,,,,,,,,,,,,,,,,,,,,,
,39.01,0.820,,,,,,,,,,,,,,,,,,,,,,,
,39.28,0.725,,,,,,,,,,,,,,,,,,,,,,,
,39.56,0.115,,,,,,,,,,,,,,,,,,,,,,,
,39.83,0.120,,,,,,,,,,,,,,,,,,,,,,,
,40.09,0.360,,,,,,,,,,,,,,,,,,,,,,,
,40.36,0.825,,,,,,,,,,,,,,,,,,,,,,,
,40.63,0.790,,,,,,,,,,,,,,,,,,,,,,,
,40.88,0.805,,,,,,,,,,,,,,,,,,,,,,,
,41.13,0.725,,,,,,,,,,,,,,,,,,,,,,,
,41.39,0.360,,,,,,,,,,,,,,,,,,,,,,,
,41.65,0.110,,,,,,,,,,,,,,,,,,,,,,,
,41.92,0.090,,,,,,,,,,,,,,,,,,,,,,,
,42.17,0.090,,,,,,,,,,,,,,,,,,,,,,,
,42.43,0.090,,,,,,,,,,,,,,,,,,,,,,,
,42.69,0.080,,,,,,,,,,,,,,,,,,,,,,,
,42.95,0.130,,,,,,,,,,,,,,,,,,,,,,,
,43.20,0.360,,,,,,,,,,,,,,,,,,,,,,,
,43.45,0.735,,,,,,,,,,,,,,,,,,,,,,,
,43.73,0.635,,,,,,,,,,,,,,,,,,,,,,,
,43.99,0.125,,,,,,,,,,,,,,,,,,,,,,,
,44.25,0.320,,,,,,,,,,,,,,,,,,,,,,,
,44.53,0.845,,,,,,,,,,,,,,,,,,,,,,,
,44.83,0.855,,,,,,,,,,,,,,,,,,,,,,,
,45.10,0.840,,,,,,,,,,,,,,,,,,,,,,,
,45.37,0.850,,,,,,,,,,,,,,,,,,,,,,,
,45.62,0.845,,,,,,,,,,,,,,,,,,,,,,,
,45.88,0.740,,,,,,,,,,,,,,,,,,,,,,,
,46.14,0.305,,,,,,,,,,,,,,,,,,,,,,,
,46.41,0.285,,,,,,,,,,,,,,,,,,,,,,,
,46.67,0.135,,,,,,,,,,,,,,,,,,,,,,,
,46.95,0.410,,,,,,,,,,,,,,,,,,,,,,,
,47.22,0.730,,,,,,,,,,,,,,,,,,,,,,,
,47.48,0.820,,,,,,,,,,,,,,,,,,,,,,,
,47.74,0.775,,,,,,,,,,,,,,,,,,,,,,,
,48.00,0.770,,,,,,,,,,,,,,,,,,,,,,,
,48.26,0.755,,,,,,,,,,,,,,,,,,,,,,,
,48.53,0.600,,,,,,,,,,,,,,,,,,,,,,,
,48.80,0.200,,,,,,,,,,,,,,,,,,,,,,,
,49.06,0.275,,,,,,,,,,,,,,,,,,,,,,,
,49.32,0.695,,,,,,,,,,,,,,,,,,,,,,,
,49.58,0.795,,,,,,,,,,,,,,,,,,,,,,,
,49.83,0.770,,,,,,,,,,,,,,,,,,,,,,,
,50.08,0.560,,,,,,,,,,,,,,,,,,,,,,,
,50.34,0.155,,,,,,,,,,,,,,,,,,,,,,,
,50.61,0.165,,,,,,,,,,,,,,,,,,,,,,,
,50.87,0.850,,,,,,,,,,,,,,,,,,,,,,,
,51.13,0.785,,,,,,,,,,,,,,,,,,,,,,,
,51.39,0.850,,,,,,,,,,,,,,,,,,,,,,,
,51.65,0.865,,,,,,,,,,,,,,,,,,,,,,,
,51.92,0.845,,,,,,,,,,,,,,,,,,,,,,,
,52.18,0.830,,,,,,,,,,,,,,,,,,,,,,,
,52.44,0.850,,,,,,,,,,,,,,,,,,,,,,,
,52.71,0.785,,,,,,,,,,,,,,,,,,,,,,,
,52.96,0.500,,,,,,,,,,,,,,,,,,,,,,,
,53.21,0.205,,,,,,,,,,,,,,,,,,,,,,,
,53.48,0.100,,,,,,,,,,,,,,,,,,,,,,,
,53.73,0.090,,,,,,,,,,,,,,,,,,,,,,,
,54.00,0.560,,,,,,,,,,,,,,,,,,,,,,,
,54.24,0.795,,,,,,,,,,,,,,,,,,,,,,,
,54.49,0.730,,,,,,,,,,,,,,,,,,,,,,,
,54.74,0.105,,,,,,,,,,,,,,,,,,,,,,,
,55.00,0.090,,,,,,,,,,,,,,,,,,,,,,,
,55.26,0.095,,,,,,,,,,,,,,,,,,,,,,,
,55.54,0.105,,,,,,,,,,,,,,,,,,,,,,,
,55.80,0.220,,,,,,,,,,,,,,,,,,,,,,,
,56.07,0.105,,,,,,,,,,,,,,,,,,,,,,,
,56.35,0.085,,,,,,,,,,,,,,,,,,,,,,,
,56.61,0.540,,,,,,,,,,,,,,,,,,,,,,,
,56.87,0.750,,,,,,,,,,,,,,,,,,,,,,,
,57.12,0.705,,,,,,,,,,,,,,,,,,,,,,,
,57.38,0.140,,,,,,,,,,,,,,,,,,,,,,,
,57.63,0.085,,,,,,,,,,,,,,,,,,,,,,,
,57.89,0.085,,,,,,,,,,,,,,,,,,,,,,,
,58.14,0.205,,,,,,,,,,,,,,,,,,,,,,,
,58.40,0.640,,,,,,,,,,,,,,,,,,,,,,,
,58.68,0.805,,,,,,,,,,,,,,,,,,,,,,,
,58.94,0.375,,,,,,,,,,,,,,,,,,,,,,,
,59.21,0.815,,,,,,,,,,,,,,,,,,,,,,,
,59.47,0.845,,,,,,,,,,,,,,,,,,,,,,,
,59.73,0.870,,,,,,,,,,,,,,,,,,,,,,,
,59.99,0.840,,,,,,,,,,,,,,,,,,,,,,,
,60.25,0.275,,,,,,,,,,,,,,,,,,,,,,,
,60.53,0.065,,,,,,,,,,,,,,,,,,,,,,,
,60.79,0.050,,,,,,,,,,,,,,,,,,,,,,,
,61.05,0.570,,,,,,,,,,,,,,,,,,,,,,,
,61.30,0.500,,,,,,,,,,,,,,,,,,,,,,,
,61.55,0.310,,,,,,,,,,,,,,,,,,,,,,,
,61.80,0.275,,,,,,,,,,,,,,,,,,,,,,,
,62.06,0.860,,,,,,,,,,,,,,,,,,,,,,,
,62.31,0.845,,,,,,,,,,,,,,,,,,,,,,,
,62.57,0.410,,,,,,,,,,,,,,,,,,,,,,,
,62.84,0.090,,,,,,,,,,,,,,,,,,,,,,,
,63.10,0.075,,,,,,,,,,,,,,,,,,,,,,,
,63.37,0.070,,,,,,,,,,,,,,,,,,,,,,,
,63.63,0.075,,,,,,,,,,,,,,,,,,,,,,,
,63.90,0.095,,,,,,,,,,,,,,,,,,,,,,,
,64.16,0.380,,,,,,,,,,,,,,,,,,,,,,,
,64.42,0.865,,,,,,,,,,,,,,,,,,,,,,,
,64.69,0.880,,,,,,,,,,,,,,,,,,,,,,,
,64.97,0.880,,,,,,,,,,,,,,,,,,,,,,,
,65.23,0.830,,,,,,,,,,,,,,,,,,,,,,,
,65.50,0.850,,,,,,,,,,,,,,,,,,,,,,,
,65.76,0.865,,,,,,,,,,,,,,,,,,,,,,,
,66.01,0.855,,,,,,,,,,,,,,,,,,,,,,,
,66.27,0.860,,,,,,,,,,,,,,,,,,,,,,,
,66.54,0.860,,,,,,,,,,,,,,,,,,,,,,,
,66.80,0.810,,,,,,,,,,,,,,,,,,,,,,,
,67.06,0.720,,,,,,,,,,,,,,,,,,,,,,,
,67.32,0.240,,,,,,,,,,,,,,,,,,,,,,,
,67.57,0.120,,,,,,,,,,,,,,,,,,,,,,,
,67.82,0.090,,,,,,,,,,,,,,,,,,,,,,,
,68.08,0.085,,,,,,,,,,,,,,,,,,,,,,,
,68.33,0.085,,,,,,,,,,,,,,,,,,,,,,,
,68.59,0.620,,,,,,,,,,,,,,,,,,,,,,,
,68.86,0.100,,,,,,,,,,,,,,,,,,,,,,,
,69.11,0.085,,,,,,,,,,,,,,,,,,,,,,,
,69.36,0.245,,,,,,,,,,,,,,,,,,,,,,,
,69.61,0.815,,,,,,,,,,,,,,,,,,,,,,,
,69.86,0.830,,,,,,,,,,,,,,,,,,,,,,,
,70.11,0.810,,,,,,,,,,,,,,,,,,,,,,,
,70.40,0.785,,,,,,,,,,,,,,,,,,,,,,,
,70.66,0.855,,,,,,,,,,,,,,,,,,,,,,,
,70.93,0.825,,,,,,,,,,,,,,,,,,,,,,,
,71.19,0.270,,,,,,,,,,,,,,,,,,,,,,,
,71.45,0.070,,,,,,,,,,,,,,,,,,,,,,,
,71.70,0.065,,,,,,,,,,,,,,,,,,,,,,,
,71.97,0.065,,,,,,,,,,,,,,,,,,,,,,,
,72.24,0.080,,,,,,,,,,,,,,,,,,,,,,,
,72.52,0.225,,,,,,,,,,,,,,,,,,,,,,,
,72.79,0.715,,,,,,,,,,,,,,,,,,,,,,,
,73.04,0.835,,,,,,,,,,,,,,,,,,,,,,,
,73.29,0.850,,,,,,,,,,,,,,,,,,,,,,,
,73.55,0.850,,,,,,,,,,,,,,,,,,,,,,,
,73.81,0.600,,,,,,,,,,,,,,,,,,,,,,,
,74.07,0.135,,,,,,,,,,,,,,,,,,,,,,,
,74.32,0.090,,,,,,,,,,,,,,,,,,,,,,,
,74.57,0.090,,,,,,,,,,,,,,,,,,,,,,,
,74.82,0.090,,,,,,,,,,,,,,,,,,,,,,,
,75.09,0.720,,,,,,,,,,,,,,,,,,,,,,,
,75.36,0.845,,,,,,,,,,,,,,,,,,,,,,,
,75.62,0.835,,,,,,,,,,,,,,,,,,,,,,,
,75.88,0.805,,,,,,,,,,,,,,,,,,,,,,,
,76.15,0.585,,,,,,,,,,,,,,,,,,,,,,,
,76.40,0.180,,,,,,,,,,,,,,,,,,,,,,,
,76.67,0.125,,,,,,,,,,,,,,,,,,,,,,,
,76.95,0.570,,,,,,,,,,,,,,,,,,,,,,,
,77.21,0.835,,,,,,,,,,,,,,,,,,,,,,,
,77.47,0.840,,,,,,,,,,,,,,,,,,,,,,,
,77.73,0.795,,,,,,,,,,,,,,,,,,,,,,,
,77.98,0.810,,,,,,,,,,,,,,,,,,,,,,,
,78.24,0.800,,,,,,,,,,,,,,,,,,,,,,,
,78.50,0.515,,,,,,,,,,,,,,,,,,,,,,,
,78.76,0.760,,,,,,,,,,,,,,,,,,,,,,,
,79.01,0.800,,,,,,,,,,,,,,,,,,,,,,,
,79.27,0.845,,,,,,,,,,,,,,,,,,,,,,,
,79.53,0.855,,,,,,,,,,,,,,,,,,,,,,,
,79.79,0.835,,,,,,,,,,,,,,,,,,,,,,,
,80.05,0.790,,,,,,,,,,,,,,,,,,,,,,,
,80.32,0.545,,,,,,,,,,,,,,,,,,,,,,,
,80.57,0.125,,,,,,,,,,,,,,,,,,,,,,,
,80.83,0.090,,,,,,,,,,,,,,,,,,,,,,,
,81.08,0.085,,,,,,,,,,,,,,,,,,,,,,,
,81.32,0.090,,,,,,,,,,,,,,,,,,,,,,,
,81.58,0.115,,,,,,,,,,,,,,,,,,,,,,,
,81.83,0.130,,,,,,,,,,,,,,,,,,,,,,,
,82.11,0.625,,,,,,,,,,,,,,,,,,,,,,,
,82.35,0.810,,,,,,,,,,,,,,,,,,,,,,,
,82.61,0.800,,,,,,,,,,,,,,,,,,,,,,,
,82.87,0.210,,,,,,,,,,,,,,,,,,,,,,,
,83.16,0.080,,,,,,,,,,,,,,,,,,,,,,,
,83.43,0.075,,,,,,,,,,,,,,,,,,,,,,,
,83.70,0.095,,,,,,,,,,,,,,,,,,,,,,,
,83.97,0.150,,,,,,,,,,,,,,,,,,,,,,,
,84.27,0.695,,,,,,,,,,,,,,,,,,,,,,,
,84.54,0.775,,,,,,,,,,,,,,,,,,,,,,,
,84.84,0.655,,,,,,,,,,,,,,,,,,,,,,,
,85.09,0.205,,,,,,,,,,,,,,,,,,,,,,,
,85.35,0.725,,,,,,,,,,,,,,,,,,,,,,,
,85.61,0.780,,,,,,,,,,,,,,,,,,,,,,,
,85.90,0.665,,,,,,,,,,,,,,,,,,,,,,,
,86.15,0.790,,,,,,,,,,,,,,,,,,,,,,,
,86.41,0.795,,,,,,,,,,,,,,,,,,,,,,,
,86.69,0.085,,,,,,,,,,,,,,,,,,,,,,,
,86.96,0.065,,,,,,,,,,,,,,,,,,,,,,,
,87.22,0.420,,,,,,,,,,,,,,,,,,,,,,,
,87.50,0.860,,,,,,,,,,,,,,,,,,,,,,,
,87.77,0.835,,,,,,,,,,,,,,,,,,,,,,,
,88.04,0.795,,,,,,,,,,,,,,,,,,,,,,,
,88.32,0.850,,,,,,,,,,,,,,,,,,,,,,,
,88.58,0.835,,,,,,,,,,,,,,,,,,,,,,,
,88.83,0.570,,,,,,,,,,,,,,,,,,,,,,,
,89.08,0.070,,,,,,,,,,,,,,,,,,,,,,,
,89.33,0.070,,,,,,,,,,,,,,,,,,,,,,,
,89.61,0.070,,,,,,,,,,,,,,,,,,,,,,,
,89.86,0.100,,,,,,,,,,,,,,,,,,,,,,,
,90.11,0.385,,,,,,,,,,,,,,,,,,,,,,,
,90.36,0.825,,,,,,,,,,,,,,,,,,,,,,,
,90.61,0.830,,,,,,,,,,,,,,,,,,,,,,,
,90.87,0.800,,,,,,,,,,,,,,,,,,,,,,,
,91.12,0.780,,,,,,,,,,,,,,,,,,,,,,,
,91.39,0.825,,,,,,,,,,,,,,,,,,,,,,,
,91.66,0.375,,,,,,,,,,,,,,,,,,,,,,,
,91.92,0.085,,,,,,,,,,,,,,,,,,,,,,,
,92.18,0.085,,,,,,,,,,,,,,,,,,,,,,,
,92.43,0.110,,,,,,,,,,,,,,,,,,,,,,,
,92.68,0.835,,,,,,,,,,,,,,,,,,,,,,,
,92.94,0.825,,,,,,,,,,,,,,,,,,,,,,,
,93.20,0.730,,,,,,,,,,,,,,,,,,,,,,,
,93.46,0.225,,,,,,,,,,,,,,,,,,,,,,,
,93.72,0.100,,,,,,,,,,,,,,,,,,,,,,,
,93.99,0.095,,,,,,,,,,,,,,,,,,,,,,,
,94.25,0.100,,,,,,,,,,,,,,,,,,,,,,,
,94.53,0.260,,,,,,,,,,,,,,,,,,,,,,,
,94.78,0.820,,,,,,,,,,,,,,,,,,,,,,,
,95.04,0.850,,,,,,,,,,,,,,,,,,,,,,,
,95.31,0.840,,,,,,,,,,,,,,,,,,,,,,,
,95.58,0.835,,,,,,,,,,,,,,,,,,,,,,,
,95.84,0.480,,,,,,,,,,,,,,,,,,,,,,,
,96.10,0.095,,,,,,,,,,,,,,,,,,,,,,,
,96.37,0.085,,,,,,,,,,,,,,,,,,,,,,,
,96.64,0.090,,,,,,,,,,,,,,,,,,,,,,,
,96.89,0.075,,,,,,,,,,,,,,,,,,,,,,,
,97.15,0.075,,,,,,,,,,,,,,,,,,,,,,,
,97.39,0.140,,,,,,,,,,,,,,,,,,,,,,,
,97.65,0.835,,,,,,,,,,,,,,,,,,,,,,,
,97.90,0.865,,,,,,,,,,,,,,,,,,,,,,,
,98.15,0.865,,,,,,,,,,,,,,,,,,,,,,,
,98.40,0.860,,,,,,,,,,,,,,,,,,,,,,,
,98.66,0.860,,,,,,,,,,,,,,,,,,,,,,,
,98.92,0.855,,,,,,,,,,,,,,,,,,,,,,,
,99.19,0.845,,,,,,,,,,,,,,,,,,,,,,,
,99.45,0.850,,,,,,,,,,,,,,,,,,,,,,,
,99.72,0.855,,,,,,,,,,,,,,,,,,,,,,,
,99.98,0.855,,,,,,,,,,,,,,,,,,,,,,,
,100.25,0.840,,,,,,,,,,,,,,,,,,,,,,,
,100.50,0.820,,,,,,,,,,,,,,,,,,,,,,,
,100.75,0.815,,,,,,,,,,,,,,,,,,,,,,,
,101.00,0.735,,,,,,,,,,,,,,,,,,,,,,,
,101.25,0.565,,,,,,,,,,,,,,,,,,,,,,,
,101.51,0.090,,,,,,,,,,,,,,,,,,,,,,,
,101.78,0.080,,,,,,,,,,,,,,,,,,,,,,,
,102.03,0.070,,,,,,,,,,,,,,,,,,,,,,,
,102.29,0.060,,,,,,,,,,,,,,,,,,,,,,,
,102.56,0.060,,,,,,,,,,,,,,,,,,,,,,,
,102.82,0.070,,,,,,,,,,,,,,,,,,,,,,,
,103.10,0.120,,,,,,,,,,,,,,,,,,,,,,,
,103.36,0.060,,,,,,,,,,,,,,,,,,,,,,,
,103.63,0.540,,,,,,,,,,,,,,,,,,,,,,,
,103.90,0.845,,,,,,,,,,,,,,,,,,,,,,,
,104.16,0.825,,,,,,,,,,,,,,,,,,,,,,,
,104.44,0.835,,,,,,,,,,,,,,,,,,,,,,,
,104.71,0.790,,,,,,,,,,,,,,,,,,,,,,,
,104.96,0.660,,,,,,,,,,,,,,,,,,,,,,,
,105.23,0.290,,,,,,,,,,,,,,,,,,,,,,,
,105.49,0.185,,,,,,,,,,,,,,,,,,,,,,,
,105.74,0.195,,,,,,,,,,,,,,,,,,,,,,,
,105.99,0.600,,,,,,,,,,,,,,,,,,,,,,,
,106.25,0.810,,,,,,,,,,,,,,,,,,,,,,,
,106.52,0.810,,,,,,,,,,,,,,,,,,,,,,,
,106.78,0.800,,,,,,,,,,,,,,,,,,,,,,,
,107.05,0.770,,,,,,,,,,,,,,,,,,,,,,,
,107.31,0.595,,,,,,,,,,,,,,,,,,,,,,,
,107.57,0.285,,,,,,,,,,,,,,,,,,,,,,,
,107.84,0.280,,,,,,,,,,,,,,,,,,,,,,,
,108.12,0.605,,,,,,,,,,,,,,,,,,,,,,,
,108.38,0.755,,,,,,,,,,,,,,,,,,,,,,,
,108.67,0.820,,,,,,,,,,,,,,,,,,,,,,,
,108.92,0.815,,,,,,,,,,,,,,,,,,,,,,,
,109.17,0.810,,,,,,,,,,,,,,,,,,,,,,,
,109.42,0.805,,,,,,,,,,,,,,,,,,,,,,,
,109.67,0.775,,,,,,,,,,,,,,,,,,,,,,,
,109.92,0.690,,,,,,,,,,,,,,,,,,,,,,,
,110.19,0.185,,,,,,,,,,,,,,,,,,,,,,,
,110.47,0.105,,,,,,,,,,,,,,,,,,,,,,,
,110.72,0.135,,,,,,,,,,,,,,,,,,,,,,,
,110.98,0.730,,,,,,,,,,,,,,,,,,,,,,,
,111.23,0.860,,,,,,,,,,,,,,,,,,,,,,,
,111.49,0.825,,,,,,,,,,,,,,,,,,,,,,,
,111.76,0.225,,,,,,,,,,,,,,,,,,,,,,,
,112.01,0.070,,,,,,,,,,,,,,,,,,,,,,,
,112.29,0.065,,,,,,,,,,,,,,,,,,,,,,,
,112.55,0.065,,,,,,,,,,,,,,,,,,,,,,,
,112.82,0.065,,,,,,,,,,,,,,,,,,,,,,,
,113.07,0.075,,,,,,,,,,,,,,,,,,,,,,,
,113.32,0.100,,,,,,,,,,,,,,,,,,,,,,,
,113.57,0.525,,,,,,,,,,,,,,,,,,,,,,,
,113.82,0.830,,,,,,,,,,,,,,,,,,,,,,,
,114.08,0.850,,,,,,,,,,,,,,,,,,,,,,,
,114.34,0.855,,,,,,,,,,,,,,,,,,,,,,,
,114.61,0.835,,,,,,,,,,,,,,,,,,,,,,,
,114.86,0.800,,,,,,,,,,,,,,,,,,,,,,,
,115.11,0.800,,,,,,,,,,,,,,,,,,,,,,,
,115.36,0.805,,,,,,,,,,,,,,,,,,,,,,,
,115.61,0.835,,,,,,,,,,,,,,,,,,,,,,,
,115.86,0.850,,,,,,,,,,,,,,,,,,,,,,,
,116.12,0.850,,,,,,,,,,,,,,,,,,,,,,,
,116.38,0.845,,,,,,,,,,,,,,,,,,,,,,,
,116.64,0.845,,,,,,,,,,,,,,,,,,,,,,,
,116.89,0.865,,,,,,,,,,,,,,,,,,,,,,,
,117.15,0.750,,,,,,,,,,,,,,,,,,,,,,,
,117.41,0.250,,,,,,,,,,,,,,,,,,,,,,,
,117.68,0.075,,,,,,,,,,,,,,,,,,,,,,,
,117.95,0.070,,,,,,,,,,,,,,,,,,,,,,,
,118.20,0.075,,,,,,,,,,,,,,,,,,,,,,,
,118.47,0.075,,,,,,,,,,,,,,,,,,,,,,,
,118.74,0.095,,,,,,,,,,,,,,,,,,,,,,,
,118.99,0.130,,,,,,,,,,,,,,,,,,,,,,,
,119.27,0.230,,,,,,,,,,,,,,,,,,,,,,,
,119.52,0.840,,,,,,,,,,,,,,,,,,,,,,,
,119.78,0.855,,,,,,,,,,,,,,,,,,,,,,,
,120.06,0.860,,,,,,,,,,,,,,,,,,,,,,,
,120.35,0.855,,,,,,,,,,,,,,,,,,,,,,,
,120.63,0.830,,,,,,,,,,,,,,,,,,,,,,,
,120.89,0.745,,,,,,,,,,,,,,,,,,,,,,,
,121.14,0.495,,,,,,,,,,,,,,,,,,,,,,,
,121.40,0.190,,,,,,,,,,,,,,,,,,,,,,,
,121.66,0.195,,,,,,,,,,,,,,,,,,,,,,,
,121.92,0.760,,,,,,,,,,,,,,,,,,,,,,,
,122.18,0.815,,,,,,,,,,,,,,,,,,,,,,,
,122.44,0.820,,,,,,,,,,,,,,,,,,,,,,,
,122.69,0.840,,,,,,,,,,,,,,,,,,,,,,,
,122.99,0.790,,,,,,,,,,,,,,,,,,,,,,,
,123.25,0.100,,,,,,,,,,,,,,,,,,,,,,,
,123.53,0.045,,,,,,,,,,,,,,,,,,,,,,,
,123.80,0.080,,,,,,,,,,,,,,,,,,,,,,,
,124.06,0.800,,,,,,,,,,,,,,,,,,,,,,,
,124.33,0.855,,,,,,,,,,,,,,,,,,,,,,,
,124.61,0.860,,,,,,,,,,,,,,,,,,,,,,,
,124.87,0.460,,,,,,,,,,,,,,,,,,,,,,,
,125.14,0.110,,,,,,,,,,,,,,,,,,,,,,,
,125.41,0.765,,,,,,,,,,,,,,,,,,,,,,,
,125.67,0.835,,,,,,,,,,,,,,,,,,,,,,,
,125.95,0.795,,,,,,,,,,,,,,,,,,,,,,,
,126.21,0.840,,,,,,,,,,,,,,,,,,,,,,,
,126.48,0.865,,,,,,,,,,,,,,,,,,,,,,,
,126.74,0.780,,,,,,,,,,,,,,,,,,,,,,,
,126.99,0.340,,,,,,,,,,,,,,,,,,,,,,,
,127.25,0.075,,,,,,,,,,,,,,,,,,,,,,,
,127.51,0.075,,,,,,,,,,,,,,,,,,,,,,,
,127.77,0.120,,,,,,,,,,,,,,,,,,,,,,,
,128.03,0.095,,,,,,,,,,,,,,,,,,,,,,,
,128.29,0.140,,,,,,,,,,,,,,,,,,,,,,,
,128.55,0.725,,,,,,,,,,,,,,,,,,,,,,,
,128.82,0.760,,,,,,,,,,,,,,,,,,,,,,,
,129.08,0.600,,,,,,,,,,,,,,,,,,,,,,,
,129.33,0.250,,,,,,,,,,,,,,,,,,,,,,,
,129.61,0.555,,,,,,,,,,,,,,,,,,,,,,,
,129.89,0.680,,,,,,,,,,,,,,,,,,,,,,,
,130.16,0.745,,,,,,,,,,,,,,,,,,,,,,,
,130.42,0.230,,,,,,,,,,,,,,,,,,,,,,,
,130.68,0.110,,,,,,,,,,,,,,,,,,,,,,,
,130.95,0.190,,,,,,,,,,,,,,,,,,,,,,,
,131.20,0.690,,,,,,,,,,,,,,,,,,,,,,,
,131.45,0.855,,,,,,,,,,,,,,,,,,,,,,,
,131.72,0.870,,,,,,,,,,,,,,,,,,,,,,,
,132.00,0.810,,,,,,,,,,,,,,,,,,,,,,,
,132.27,0.820,,,,,,,,,,,,,,,,,,,,,,,
,132.53,0.860,,,,,,,,,,,,,,,,,,,,,,,
,132.79,0.790,,,,,,,,,,,,,,,,,,,,,,,
,133.04,0.825,,,,,,,,,,,,,,,,,,,,,,,
,133.31,0.865,,,,,,,,,,,,,,,,,,,,,,,
,133.57,0.860,,,,,,,,,,,,,,,,,,,,,,,
,133.82,0.875,,,,,,,,,,,,,,,,,,,,,,,
,134.08,0.875,,,,,,,,,,,,,,,,,,,,,,,
,134.34,0.865,,,,,,,,,,,,,,,,,,,,,,,
,134.60,0.815,,,,,,,,,,,,,,,,,,,,,,,
,134.88,0.735,,,,,,,,,,,,,,,,,,,,,,,
,135.13,0.605,,,,,,,,,,,,,,,,,,,,,,,
,135.39,0.200,,,,,,,,,,,,,,,,,,,,,,,
,135.66,0.090,,,,,,,,,,,,,,,,,,,,,,,
,135.93,0.080,,,,,,,,,,,,,,,,,,,,,,,
,136.20,0.075,,,,,,,,,,,,,,,,,,,,,,,
,136.46,0.075,,,,,,,,,,,,,,,,,,,,,,,
,136.72,0.080,,,,,,,,,,,,,,,,,,,,,,,
,136.97,0.075,,,,,,,,,,,,,,,,,,,,,,,
,137.22,0.075,,,,,,,,,,,,,,,,,,,,,,,
,137.47,0.070,,,,,,,,,,,,,,,,,,,,,,,
,137.74,0.070,,,,,,,,,,,,,,,,,,,,,,,
,138.00,0.065,,,,,,,,,,,,,,,,,,,,,,,
,138.25,0.070,,,,,,,,,,,,,,,,,,,,,,,
,138.51,0.070,,,,,,,,,,,,,,,,,,,,,,,
,138.76,0.075,,,,,,,,,,,,,,,,,,,,,,,
,139.03,0.085,,,,,,,,,,,,,,,,,,,,,,,
,139.29,0.085,,,,,,,,,,,,,,,,,,,,,,,
,139.59,0.085,,,,,,,,,,,,,,,,,,,,,,,
,139.87,0.075,,,,,,,,,,,,,,,,,,,,,,,
,140.14,0.070,,,,,,,,,,,,,,,,,,,,,,,
,140.40,0.355,,,,,,,,,,,,,,,,,,,,,,,
,140.67,0.710,,,,,,,,,,,,,,,,,,,,,,,
,140.93,0.795,,,,,,,,,,,,,,,,,,,,,,,
,141.19,0.815,,,,,,,,,,,,,,,,,,,,,,,
,141.44,0.795,,,,,,,,,,,,,,,,,,,,,,,
,141.70,0.760,,,,,,,,,,,,,,,,,,,,,,,
,141.95,0.295,,,,,,,,,,,,,,,,,,,,,,,
,142.20,0.080,,,,,,,,,,,,,,,,,,,,,,,
,142.46,0.065,,,,,,,,,,,,,,,,,,,,,,,
If i press full throttle so it should use fuel mapping instead of lambda i get backfires continiously on lower revs and on higher revs no power...
Old Jan 13, 2013 | 01:40 PM
q139's Avatar
3r cylinder spark plug is dark and others have bit of yellow.
Old Jan 13, 2013 | 03:00 PM
q139's Avatar
seems i found 1 bad sparkplug fire , same one that carbon fouled.
Could this cause all of my problems , backfire loss of power etc?
AmandaLee80
Apr 24, 2011 09:30 PM
Mininger
Aug 29, 2008 04:09 PM
tooxtreme8813
Dec 15, 2006 06:43 PM
///A4
Feb 2, 2006 12:27 PM
99AudiA4q
Dec 21, 2004 02:58 AM
