Bad u joint?
So, I have a 98 audi a4 quattro 1.8t. Ive had this issue for a while and I think I finally found the issue but im not sure. During acceleration my car shakes a lot and flashes all the dash lights. (Oil, seatbelt, coolant, etc no check engine) I recently went under the car and I wiggled the drive shaft and it had some play. Could it be my u joint and how difficult is it to fix? If like to do it myself because a shop would cost an arm and a leg as every service does. Opinions?
There are no "U-joints" on your A4, with the exception of the one for the steering wheel. You may indeed have a bad Constant-Velocity (CV) joint; a loose or broken inner joint will vibrate under acceleration. But you obviously have electrical issues that have to be sorted out, which are causing the dash lights. Get the codes scanned and post them.
