Bailey DV Installed
Old Nov 16, 2009 | 12:05 AM
codymack43's Avatar
Thumbs up Bailey DV Installed
Just got finished installing my new DV my car. I picked up a never used baliey DV - the one that AWE tuning sells, for $150 from a guy i found in allofcraigs. Just thought I'd do a quick little write up on it.
AWE's DV
IMG_0262.jpg?t=1258347340
This is the kit, comes with new clamps and everything, and boy did i need them...
IMG_0265.jpg?t=1258347452
Crappy plastic stock one, Notice that rusted through bolt, yeah that was a bitch to get off...
IMG_0266.jpg?t=1258347492
After 30 mins of prying the old clamps off I finally got it out, notice how much bigger and nicer the bailey is
IMG_0267.jpg?t=1258347551
Another 15 mins to put the new one in and clamp it down and we're good to go!
IMG_0268.jpg?t=1258347596
How nice and shiny
All in all, i gotta say I haven't noticed a HUGE difference in performance yet, but I did notice. There is definitely less lag and it punches into second and third harder. I thought It would be louder though, but the actual sound that comes from it isn't really noticeable. I thought it would sound a little more like the forge 007.
But I like it, and it will certainly be good for the turbo once I chip and push more boost through it. AWE rates it around a 13hp increase on a chipped 1.8t in a new beetle. I wish i had a boost gauge so i could see exactly what its doing for the psi, oh well lol...
OH! while i'm at it. My car makes this ticking noise when it runs. It basically sounds like something is hitting the fan, but theres nothing there. It sounds like it's coming from the actual block. It goes with the revs too. but its only really noticeable in neutral and first, then dies away in second... any ideas?
Old Nov 16, 2009 | 12:17 AM
kriptonik's Avatar
Any sound clip?
BTW - are you running an intake mod of some sort? If you want the sound, you will need to get an aftermarket box or mod the intake.
Old Nov 16, 2009 | 12:26 AM
codymack43's Avatar
No... stock airbox :/
I was thinking of getting an intake but since it doesnt really get me anywhere on performance its low priority lol..
But I think a sound vid would be redundant just because it doesnt sound any different... but... maybe i should so we can diagnose that damn ticking...
Old Nov 16, 2009 | 12:46 AM
kriptonik's Avatar
I think that ticking sound would be the failing cam tensioner.
It's a pretty common problem for 1.8T's.
Old Nov 16, 2009 | 12:48 AM
codymack43's Avatar
and whats the fix on it? Is it going to be an issue?
Old Nov 16, 2009 | 01:03 AM
kriptonik's Avatar
Well, if it's the cam chain tensioner, you will need that replaced.
Is the ticking coming from the back of the head?
Old Nov 16, 2009 | 01:08 AM
collins's Avatar
aeb & atw - http://www.ecstuning.com/Audi-B5_A4-...oner/ES260023/
aug & awm - http://www.ecstuning.com/Audi-B5_A4-...sioner/ES8702/
and you have to take the head apart to replace this, probably would want a mechanic to do this if you dont know what you are doing.
Old Nov 16, 2009 | 01:13 AM
kayakman13's Avatar
Are you sure its not the injectors? they have a hydraulic tick. Also, theres a little check valve right above your air box, it sits on top. Mine clicks awfully loudly. Finally, move the steering wheel. Its probably not that, but my pwr steering starting making a ton of noise one day for no apparent reason. Moved the wheel and it went away.
Old Nov 16, 2009 | 08:41 AM
codymack43's Avatar
I know that tick youre talking about, and it does have that, but i think that it is the cam tensioner...
I need to do my timing belt here pretty soon anyways, is that something that would be on the way to the belt?
Old Nov 16, 2009 | 02:58 PM
collins's Avatar
not really its on the other side of the head. if your having a shop do your timing belt you should probably just get this done at the same time though.
