before/after pics spacers and/or rolled fenders?
Old Apr 5, 2008 | 05:03 PM
CAB509's Avatar
6th Gear
Default RE: before/after pics spacers and/or rolled fenders?
coil overs usually have a stiffer spring rate then stock springs and even lowering springs plus on some models you can adjust the rebound and make them even stiffer if you want to. So when people say they loose ride quality they are truly referring to comfort because the stiffer suspension means that it is not going to absorb the changes in the road as smoothly as a softer spring. But the trade off is a lower center of gravity, and since the suspension is stiffer you get less body roll, which allows you to take corners at a higher rate of speed.
So if you get some C/O's which are basically made for solely track duty, you would probably lose your teeth on a normal road, but many C/O's can work well on both track and street duties and give you increased performance with only a little loss of absorption properties, and that is what most guys here will end up buying unless they opt for lowering springs.
Old Apr 6, 2008 | 12:37 PM
410ThirtyValve's Avatar
Gotcha. Thanks again for the schooling.
Old Apr 6, 2008 | 06:58 PM
01AudiA4's Avatar
God i want to get bigger wheels roll my fenders and drop my car some moree---Too bad i have bills to pay.
Old Apr 6, 2008 | 09:27 PM
bolob5's Avatar
Stupid recession... Oh look tax return^^^^^^^^
Old Apr 6, 2008 | 10:09 PM
01AudiA4's Avatar
Yeah, but i have better things to put my tax return too...Vacation with the girlfriend.
Old Apr 7, 2008 | 10:42 AM
FormulaCAR's Avatar
ORIGINAL: less_of_me
fyi - you can rent a fender roller from ecodetuning.com and I would say it is one of the easiest DIY's I have done..
can you give me alittle advice as to how long it took you and if there was anything else involved that may seem important. I would also love to see a pic of your car, your sig sounds like its a pleaser
01quattro
Apr 8, 2012 10:54 PM
pbc_18
Jun 20, 2009 02:39 PM
Quattro_1.8t
May 27, 2008 07:17 AM
2KA4
Mar 11, 2007 07:30 PM
