Behind glovebox
Old Feb 13, 2008 | 04:00 PM
flyromeo3's Avatar
Default Behind glovebox
how much space is behind the glovebox.
Im hoping to re-install my sirius tuner & ipod adapter for my JVC radio. I have the 7inch single din ( AVX7010 i believe ) and it comes with a tuner box but am hesitant to start unscrewing stuff if there isnt enough room in there. I wanted to possibly place it on the passenger floor board but it doesnt look like the carpet comes off easily.
Old Feb 13, 2008 | 04:04 PM
hiwords's Avatar
Default RE: Behind glovebox
idk if there's enough room behind there but i kno there's def enough room under the passenger seat and the just run the wires under the center console or the side of the door.
Old Feb 13, 2008 | 04:22 PM
flyromeo3's Avatar
im starting to realize parts on this car dont come off as easily as an accord does. guess this is german engineering at its best.
Old Feb 13, 2008 | 04:46 PM
powersmokin's Avatar
there is not enough room to do that
Old Feb 13, 2008 | 05:11 PM
feerocknok's Avatar
Open your glovebox. Push in on the sides of the open glovebox and it will fall down much lower. Pull off the panel on the side of the dash; it is exactly like th one on the driver's side that covers the fuse panel. To drop the surround of the glovebox, undo the 2 bolts that are holding it up that are under that panel, and one bolt that is near the tranny tunnel. The one near the tranny tunnel can only be accessed when the glovebox has been dropped down as described in the first step.
This should be more than enough room to see what you're working with.
Old Feb 13, 2008 | 05:26 PM
brrman's Avatar
To completely open your glove box do it correctly . Open the box normally and then press the 2 release levers (one above each of the side runner bearings) at the same time. The glove box will fall open to the floor. It is extremely simple.
That said - I don't think you will have much room at all to work with behind the glovebox.
Old Feb 13, 2008 | 06:22 PM
ImTheDevil's Avatar
I mounted my media box on the underside of the dash on the passenger side, right over the footwell light. I removed the bulb from that side so that the bulb heat wouldn't affect the box (I doubt it would but you never know). If you get down on your back and look up at the bottom of the dash over there, you can see it. I mounted it with the inputs facing the footwell so no wires would be visible, and then just ran the iPod interface cable up into the dash and forward behind the glovebox, and then into the glovebox for the iPod. Works great, it's easily accessible for adding new components, and it's completely invisible from the seats or the street.
Stuart-kerr
Jul 27, 2009 03:52 PM
gquin1
Oct 4, 2008 12:47 PM
Bentley
May 15, 2008 03:27 PM
Jayjay
Jun 28, 2007 05:44 PM
EVOLA4
May 16, 2007 08:59 PM
