Belt Squeal when a/c is turned on...
Old Jun 25, 2010 | 12:13 AM
jhanson25's Avatar
Default Belt Squeal when a/c is turned on...
When I turn on my a/c my belt will squeal from time to time for 15-20 sec at a time. When it does squeal I don't get cold air blowing out of the vents. When the squealing stops the cold air comes back. The belt looks brand new but I am not ruling it out. Anyone else have any ideas other than a bad tensioner or belt? Thanks!!!!
Old Jun 25, 2010 | 12:50 AM
kevace1's Avatar
Most likely its a loose or bad tensioner. i suggest trying to tighten the tensioner some more. The AC tensioner is basically a pulley, and oneself is who installs the tension when its installed. this applies to the 1.8t, im not sure if the 2.8 is the same.
Old Jun 25, 2010 | 01:20 AM
jhanson25's Avatar
Where do I find the tensioner and do I just tighten it in a clockwise motion?
Old Jun 25, 2010 | 07:57 AM
kevace1's Avatar
ON the 1.8t, the ac compressor has its own tensioner, its own accessory drive belt that goes from the crank, to compressor and tensioner. The tensioner has one pivot bolt, and the other bolt is loosened and the tensioner can slide upward to create more tension. This is how to tighten the tensioner for the compressor. You can access this belt through the bottom of the car, its right there a little towards the passenger side.
Jackmup
Mar 14, 2012 02:16 PM
toolagit2qwit
Dec 22, 2011 04:46 PM
daryljwhite70
Oct 29, 2010 01:21 PM
Quis
May 27, 2006 03:29 AM
