Bit of smoke...
Old Oct 29, 2011 | 01:18 PM
B5Soldier's Avatar
Default Bit of smoke...
I have a 2001 A4 1.8T, and I notice when I Put the car in first and take off, There is a bit of smoke. Now for whatever reason I only see it in 1st on take off and when going in reverse. I noticed its considerably more smoke when it sits at idle for a bit. Its white-ish so I figured Head gasket? Any help is greatly appreciated, I'm more of a helicopter mechanic than a car mechanic
Old Oct 29, 2011 | 07:23 PM
redline380's Avatar
Legal Moderator
white smoke=coolant
blue smoke=oil
head gaskets are pretty rare to go out on these cars but possible. could also be turbo going out. is there coolant mixed with the oil or oil in the coolant?
Old Oct 30, 2011 | 02:51 PM
B5Soldier's Avatar
Well no blue, thats for sure. Its white/grey-ish. I will try and post a pic later. I mean the car has 164,XXX on the clock, and runs fine. its just that bit of smoke. What should I check first?
Old Oct 30, 2011 | 03:40 PM
1997 turbo a4's Avatar
Check your crankcase ventilation system could be clogged or could just be blow bye seals could be going thats my guess
Old Oct 30, 2011 | 03:46 PM
Try cleaning you cvs it get clogged and will not resiculate the gasses causing smoke if thats the case your front and main seal might go check that first easy and cheap take off the metal pipe and look and see if it is clogged couple cans of degreaser cheap better than seals
drummr8
Apr 5, 2013 11:52 AM
Jackmup
Sep 20, 2009 11:27 PM
eddo
Feb 20, 2009 11:18 AM
TverRus69
Oct 23, 2008 08:17 PM
