Bleed brake fluid using an air compressor?
Old May 14, 2012 | 10:40 AM
redmond1501's Avatar
Default Bleed brake fluid using an air compressor?
Anyone ever tried this method of bleeding/flushing brake fluid using an air compressor?
DIY brake flush with air compressor | HodgeBodge
Old May 14, 2012 | 11:02 AM
CCA4's Avatar
I've seen a coupla different DIY's like this. One even had instructions to build a air powered power bleeder out of a garden sprayer lol. Just be careful about how much air pressure you run through it, you don't want to start blowing up master cylinders and caliper piston seals.
Old May 14, 2012 | 02:24 PM
jonbonesjones's Avatar
Moderator
why do people need power bleeders? bleeding brakes is so fuckign easy if you can't do it you should work on cars.
Old May 14, 2012 | 03:45 PM
Speaking English is easy too, but not everyone can do it, lol.
sherlock59
B7 Models
Apr 26, 2011 11:42 AM
makav3li
Apr 18, 2010 10:52 AM
suitbandit
Apr 12, 2007 12:15 PM
edkwok
Jan 29, 2007 01:49 AM
Diavan
Dec 20, 2005 02:51 AM
