Blinker/Hazard Light Help
Old Oct 9, 2008 | 07:21 PM
onepoint8tee's Avatar
The big orange triangle switch should be for late 99+.
link (see Apps and Specs) But whatever. You know what you need. It's hard to believe the older one is more expensive.
Old Oct 10, 2008 | 10:11 AM
Tweaked's Avatar
Originally Posted by 89MustangGX
They may be for most of them -- the dealer did show different switches for early and late 98's. He had the late 98 switch in stock and showed it to me, it is just a big orange triangle. My switch (early style) is an orange triangle inside a rectangular block that matches the rest of the switches like the fog lights, etc.
Adam
The housing is just different. Later models use a large trim to cover the whole panel. Earlier switches are individual cubes like a VW. Di it fix the problem?
Old Oct 10, 2008 | 12:34 PM
89MustangGX's Avatar
The closest earlier switches in stock were 4+ hours away, so they are shipping it. Will take a few days and I will update when I get it in.
Adam
Old Oct 16, 2008 | 08:33 PM
Update: FIXED! I tackled the project yesterday. Happy to say it wasn't that difficult and the directions were right on. Hardest part was the stereo, and that was only because the aftermarket stereo that was in there was not installed correctly.
The harness is butchered and the stereo itself was sort of jammed and glued/taped in place with no dash kit. Please don't ever do that. If you do, I will get stuck with your car and have to fix it. I'm convinced of this because every car I buy is this way.
Anyway, I took the opportunity to correct the stereo install, install a dash kit (I had to modify it so the faceplate could open, I like how it came out though.), and get the hazard button changed over so the blinkers and hazard lights work. I even took a quick pic of it put back together.
Thanks again!
Adam
Attached Thumbnails Blinker/Hazard Light Help-1015081226.jpg
XmiroxX81
Feb 2, 2012 11:09 PM
gahndai
Jan 28, 2011 10:31 AM
dcam1075
Jul 25, 2008 11:29 AM
zero388
Feb 2, 2008 07:03 PM
a6avant
Feb 14, 2006 07:09 PM
