bolt in GT28RS?
http://www.034motorsport.com/product...roducts_id=268
is this a true bolt-in 28rs? I mean, it looks like it uses the same K03 exhaust flange, but doe it still use the same 3 bolt turbo-manifold flange as the stock K03 for direct fitment to the stock manifold? Kinda guessed it used the same exhaust flange from the gasket in the picture. anyone know about the manifold?
what are the downsides to this?
I guess they do leave out that it must be used in conjunction with their $780 software that comes with bigger injectors.. but still that's under $3k..
its called an elim turbo, they have a gt2x and 71r elim as well as the gtrs. you dont have you use it with their software, you have some options. Eurodyne (CTapp), Unitronics, revo (depending on your year), are the popular ones. CTapp is 700 for the tuning, your also gona need a new maf, TIP, injectors, fpr, fmic, mbc, and if you want the most out of the setup your gona have to change the exhaust manifold and downpipe as well. clutch, bigger brakes, and new mounts are also a good idea to get. and you don't have to get the turbo from 034. DTH and ATP also sell them
https://www.audiforums.com/m_816714/tm.htm
MIKA = KABOOM!
i found a gt2x with tuning and injectorson ebay and it was going cheap with no bids, after further review it was a 2x but it had mika tuning and green tops, save ur self head achs spend morenow on good parts,
sm937
Jan 21, 2013 10:19 AM
Cubanator
Nov 13, 2012 04:26 PM
